This project took about 2 - 3 hours from start to finish (not including buying the stuff).
I hope you enjoy my very first Instructable!
So the basic idea is that this is a 3-story house with roof deck. The living room is on the third floor, and has a balcony. The crane is mounted to the floor of the roof deck (the 'fourth' floor). This will allow us to pull things from the street level up to the third floor balcony. So the boom crane is saving us from having to bring things up two flights of stairs.
Remove these ads by
Signing UpStep 1Materials
Materials for the crane:
2 1/2" x 10' diameter rigid conduit
two 1/2" x 5" bolts
a bunch of 1/2" washers & nuts
1/2" x 3" eye bolt
2 1/2" pipe brackets
flat head deck screws
60 grit sand paper
I got all my stuff from Home Depot. The two pipes are surprisingly expensive, and will run you about $100. Since this will stay outdoors, make sure that everything you buy is galvanized. This will prevent any of the metal parts from rusting.
Materials for the pulley:
Double wheel pulley
Single wheel pulley with second mounting point.
carabineer
100' of strong climbing rope
40' of regular rope
I got the pulleys off of eBay for about $20 a pop. Just do a search for 'wood pulley.'
The rope was purchased from REI. This is definitely the most expensive part of the setup. Once again i wasn't sure what i would need, so i went with the sure thing. I got 11cm rope that could lift 29 kilo-Newtons. I'm not sure exactly how much that is, but the guy at the store told me it would lift a car, so it's good enough for me!
Tools:
power drill
1/2" drill bit (for metal)
compound power saw
7" cutoff blade (for metal)
safety goggles
In response to the concerns by the engineers, the rest of us are not nessesarily idiots! I have lifted 1000 pound steel beams into place with wooden derricks and a couple come alongs without incident. simple knowledge about leverage and common sense are all I have to work with.
1. Drilling a hole in a steel tube dramatically weakens it against bending failure at the hole location...right away, and even more so after a little rain and weathering. That particularly applies to the building's safety railing. If during a later party, some beefy guy leans or bumps into that railing and it fails for some stupid reason, you can bet that the fault will be assigned to that drilled hole, and whoever was responsible for drilling the hole will be up for involuntary manslaughter. Yikes.
A vastly stronger and more reliable structural approach for impromptu steel tube structures is to use swivel scaffolding clamps. They don't require any holes, they attach with included high strength fasteners, they're galvanized for fairly long outdoors life, and they're engineered for fairly high safe loads. Often you can get them from industrial supply places.
The "Kee Klamp" type of fitting is much less structurally reliable, is harder to use because the common versions require cutting the pipe/tubing, and isn't significantly cheaper.
2. The load-support eyebolt should go through a clamp as well...not through a drilled hole.
3. The load-support eyebolt should be *forged*...not a bent-steel cheapie. You can get forged eyebolts from McMaster and many other industrial hardware suppliers.
4. The lifting line should be either wire rope (with wire rope blocks) or polyester (with fiber rope blocks). Other kinds of plastic rope are designed to stretch during use, to take up shock...and you don't want *any* stretch in a lifting application, because it compromises strengh. High-flexibility wire rope plus matched-type blocks is far and away the superior way to do this job.
5. Keep everyone well away from under the load and from the upper structure. If anything breaks, not only will the load come down, but the rope will recoil upward or downward like a whip, maybe with a piece of sharp hardware on the end of it. There's plenty of history of workers having limbs cut off by whipping structural ropes/lines.
When you're doing structural-load stuff, Be Careful, and ***know what you're doing***.
