Step 2The Boom Pole
The first step is to drill some holes. The holes will all be 1/2" diameter.
While one person holds the pipe steady, the other person drills.
Put the pipe up on a piece of wood so that you don't drill through the roof!
The 2 1/2" rigid conduit will be the main boom. drill the first hole about 1/2" from the end of the pipe.
This hole is for the eyebolt.
The pipe came with a threaded connector, so i just tightened it and kept it on for stability.
It's tough to see, but try to drill as straight as possible.
Make sure to wear safety goggles, because the last thing you want is a piece of metal going in your eye.
The second hole is going to be about 2" behind the other one.
However, it needs to be at a right angle (90 degrees) from the other one.
This hole is for the support pole. It will attached to the side of the main boom.
Now we need to install the eyebolt. Insert it into the hole. On the threaded side, add one or two washers, and then a nut. Tighten this nut as hard as you can!! Then put on a second nut to keep the first one from unscrewing.
That's it for this pole!
Add Comment
