Step 8Boom Crane in action!
For the objects to be lifted, we simply used bright-orange truck tie-down straps. They're rated for like 3000 pounds, so it was more than enough. You just wrap them around an object like a present (crossed unterneath). This gives you a good point to lift from, and prevents the object from slipping out.
Well, the biggest question I'm sure you have is "How much can it lift?" Well, I didn't want to do any destructive testing to see its breaking point, because then I wouldn't have myself a cool crane any more!
But we lifted two big guys on it at one time, each weighing over 200 lbs, and there were no signs of weakening anywhere.
So I can confidently say that you can for certain lift 400 lbs on this thing. And that's a lot of weight.
Summer is coming up and we've got some great ideas for this thing, one being a tire swing! It will also make it much easier getting beer kegs up to the balcony.
Enjoy!
1. Drilling a hole in a steel tube dramatically weakens it against bending failure at the hole location...right away, and even more so after a little rain and weathering. That particularly applies to the building's safety railing. If during a later party, some beefy guy leans or bumps into that railing and it fails for some stupid reason, you can bet that the fault will be assigned to that drilled hole, and whoever was responsible for drilling the hole will be up for involuntary manslaughter. Yikes.
A vastly stronger and more reliable structural approach for impromptu steel tube structures is to use swivel scaffolding clamps. They don't require any holes, they attach with included high strength fasteners, they're galvanized for fairly long outdoors life, and they're engineered for fairly high safe loads. Often you can get them from industrial supply places.
The "Kee Klamp" type of fitting is much less structurally reliable, is harder to use because the common versions require cutting the pipe/tubing, and isn't significantly cheaper.
2. The load-support eyebolt should go through a clamp as well...not through a drilled hole.
3. The load-support eyebolt should be *forged*...not a bent-steel cheapie. You can get forged eyebolts from McMaster and many other industrial hardware suppliers.
4. The lifting line should be either wire rope (with wire rope blocks) or polyester (with fiber rope blocks). Other kinds of plastic rope are designed to stretch during use, to take up shock...and you don't want *any* stretch in a lifting application, because it compromises strengh. High-flexibility wire rope plus matched-type blocks is far and away the superior way to do this job.
5. Keep everyone well away from under the load and from the upper structure. If anything breaks, not only will the load come down, but the rope will recoil upward or downward like a whip, maybe with a piece of sharp hardware on the end of it. There's plenty of history of workers having limbs cut off by whipping structural ropes/lines.
When you're doing structural-load stuff, Be Careful, and ***know what you're doing***.
Great project!
