Boombox Light Show Pin
157
Posted
Introduction: Boombox Light Show Pin
This is a wearable pin resembling a boombox that displays a colorful animated light show.
Step 1: You Will Need
Felt (for the backing, a color of your choice)
A piece of semi-transparent plastic (I used an old terminal cover from a camera's battery)
Basic sewing supplies, needle, thread, safety pin
Paints (colors of your choosing)
Circuit Playgeound Classic with battery pack
Micro USB cable
Required software: Arduino IDE (https://www.arduino.cc/en/Main/Software)
Step 2: Begin Designing
Draw and paint your boombox design on the plastic piece. I used this basic illustration as my guide.
Make sure your plastic is at least two inches square so the circuit can fit inside.
Step 3: Backing
Cut a square from the felt and glue it onto the casing on two sides. Leave the other two open.
Sew another smaller square onto the back to act as a pocket for the battery pack. I used white thread for a cool stitched effect.
Cut tabs and sew loops to the pocket for an easy closer.
Cut a handle design out of the felt and glue on top. Sew the pin onto this piece.
Step 4: Circuit Programming
The lightshow was created with Adafruit Circuit Playground Classic (https://www.adafruit.com/product/3000).
Programming the lights was done with a project called NeoAnim, which provides an easy way to select light colors and durations by drawing the colors and patterns you need. A full description of NeoAnim can be found at https://learn.adafruit.com/circuit-playground-neoa...
I have included the picture I used to animate the lights, along with the Arduino script and header file generated by the code.
Connect the Circuit Playground to your computer using the micro USB cable. Run the Arduino IDE, load your script and header file, and transfer it to the circuit playground. Detailed instructions for this can be found at https://www.arduino.cc/en/Main/Software
Additional notes
You can create your own custom lightshows using NeoAnim. For this you will need Python and the Pillow imaging library.
https://www.python.org/downloads/
http://pillow.readthedocs.io/en/3.0.x/installation...
The script that converts your image to lightshow code is at
https://github.com/adafruit/CircuitPlaygroundMakeB...
Step 5: Assemble the Pin
Disconnect the circuit playgound from the computer, and place it inside the painted plastic. Use the felt backing's tabs and loops to hold things closed and in place. The switch on the battery pack turns the lightshow on and off.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
