Introduction: Boombox Transforms Into Car Stereo
Picture of Boombox Transforms Into Car Stereo
This instructable will guide you through installing a truly custom radio in your vehicle.  It uses the factory speakers and can look pretty nice if you try.  I had my car stolen in 2007 and they took out the CD player that the previous owner had installed.  This caused some damage that can be seen in a few pictures but basically it just left me with a hole in the dash.  I put in another amp circuit from a 5.1 system and used it for 5 years because it worked but I was never really happy with it.  I recently started entering these instructable contests and figured I should take the opportunity to redo my radio, especially after my mother-in-law gave me this malfunctioning stereo.  The CD player (which is all she used) did not work and I tried to fix it but couldn't...
So, now I have all the parts I need to install a customized, new-to-me stereo in my car.
Step 1: Take Apart the Stereo
Picture of Take Apart the Stereo
Every stereo is different but you need to find one that operates its circuitry on 12ish volts.  This is 8 batteries (AAA, AA, but probably C or D) in series... 1.5 volts x 8 = 12 volts.  You can also test the voltage on the unit but you need to be careful as you can find line voltage...  You should not plug in the stereo while it is halfway apart and touch the contacts powering the board with the voltmeter because that can be very dangerous even though it would allow you to determine the operating voltage...
I got lucky on the layout of this unit.  Different arrangements might not have been as easy to install.  You can see how much smaller it will be with the tape section removed.
Make sure to note where the power to the circuitry is coming from.  Usually it is easy to spot as a red and black cable but not always...it must originate at the power source so just start at the transformer and follow along until you get to the main circuit board.  The cable you followed was probably the power cable.
Step 2: Determine What to Keep
Picture of Determine What to Keep
Sometimes circuit boards will be all over the place... sometimes all-in-one.  All I had to do to remove the tape player section was unscrew some screws and then I used metal cutters (strong scissors) to cut off the plastic part.
Step 3: Testing Power
Picture of Testing Power
It is a good idea to test the power at least once and after major changes.  For my 12 volt source I used a backup battery/air compressor that I use to jump off the car sometimes.
Step 4: Coverting Tape Input to 1/8" Input
Picture of Coverting Tape Input to 1/8" Input
I chose to hack the tape input because the CD was more difficult (for me at least) and I wanted to keep the radio function.  The cables seen above are what were attached to the the tape player.  When looking at the tape head I saw the ground easily (attached to the head's casing) and followed it to the center pin of its plug, indicated on the picture of the circuit board.  This ground traces around the board and ends on the pin connected to the brown wire.  I am bypassing this board because the devices that will be plugged in will have their own amplification.
The 1/8" cable was threaded through a slightly enlarged microphone opening (drill) and knotted to hold securely.  I clipped and cleaned a connection on each wire in the strand and connected the brown to ground.  After plugging an MP3 player into the cable and a speaker into the left port,  I touched the signal wire (either one) to each wire and the green one was a hit so I tied them together.  Then I switched the speaker to the right port and tried the red wire on the remaining wires and the red one hit so they were tied together.  I just twisted the wires together and used electrical tape.
Step 5: Add Better Attachments
Picture of Add Better Attachments
This step is not really necessary but I wanted to wire my speaker connections to the board so I didn't have to get new connectors or cut the original speaker wires...
I simply verified the connections and soldered on my wires.  I applied hot glue to secure the wires.
Step 6: Car Prep Work
Picture of Car Prep Work
This is about what the dash looked like after the car was stolen... I found the switched power line and ground and tested them with the voltmeter.  Then I checked the fit and it was perfect.  (If it had been less than perfect I was planning to use some of that soft packing foam to help seat the radio against the dash.)
Step 7: Install New Stereo and Enjoy
Picture of Install New Stereo and Enjoy
Then I propped the radio up close to the opening and attached the power wires.  I had already wired the left positives together and the right positives together and all the negative leads together.  I attached each positive bundle to the appropriate wire on my circuit board and the negatives were all tied together and then electrical tape was applied to each connection.  I then drilled two holes in the plastic of the radio face and near the top of the dash opening and secured the radio with zip ties.
Turn the key and enjoy.
Here is a video showing operation of the input and the radio.
JakeA34 (author)2016-07-02
I've been thinking about upgrading my 90's mustang stereo. It's crap. I may try this with my Panasonic 120 watt stereo from 2004. I'm going to try to put the speakers that came with the stereo in the car. It will sound much better! Thanks for posting this! (It'll be much cheaper than buying a new stereo).
NHRAMOS (author)2016-02-08
I would keep the boombox and trash the blazer. :)
Still building robots?
10AMautomatic (author)NHRAMOS2016-02-09
hahaha awesome. I still have the Blaze, thinking of putting a little cash into it and running it around town...
of course... we have a tank the size of a golf cart... it has a pneumatic cannon... it shoots things... far. Email me if you still have mine... I can't find that cannoli address
zomfibame (author)2013-09-28
I second what Technovative said... clever, fun to see the reverse of taking an automotive radio's head unit and making it into a boom box. nicely done
technovative (author)2013-01-14
This is a clever way to hack a boombox. I think this is the first time I've seen this done, however I have seen many examples of car stereos converted into boomboxes, I've done it myself a few times. It's fun to see it flipped around.
About This Instructable
8,096views
17favorites
License:
More by 10AMautomatic:RUMBLE THE HOUSE!!Boombox Transforms Into Car StereoCar Window Fix
Add instructable to:
