Bootload an ATmega328
 by AndyTallack
Step 4: Connect your ATmega328
Now connect your ATmega to your UNO as follows:
  • UNO 5v  ---> ATmega pin 7 (VCC)
  • UNO GND  ---> ATmega pin 8 (GND)
  • UNO pin 10  ---> ATmega pin 1 (RESET)
  • UNO pin 11  ---> ATmega pin 17 (MOSI)
  • UNO pin 12  ---> ATmega pin 18 (MISO)
  • UNO pin 13  ---> ATmega pin 19 (SCK)
Make sure that you don’t have anything else connected to the ATmega pins used above.
nugrahadi says: May 20, 2013. 9:51 PM
the resistor above the led, does it connect to the ground or 5V?
AndyTallack (author) in reply to nugrahadiMay 20, 2013. 11:00 PM
It connects to GND - sorry the diagram isn't very clear. If you trace the other leg of the LED you'll see it connects to pin 13 on the Arduino, which provides a +ve source.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
