Step 4Light Assembly
iImage Information
Run the power cord through the hole in the bottle and out through the top. MAKE SURE IT IS NOT PLUGGED IN YET, you don't want 1.21 giggawatts running through your body. If you want to keep the bottle cap on, you will need to drill a hole in it as well. This is where you earn some artistic license. Since every bottle is different, it is up to you to figure out how to mount the light socket into the top of the bottle. I used one of the rubber bottle stoppers from the kit. You could also use glue or a bolt/ nut. Follow the directions on the "Lamp Kit" and wire the two wires into the socket and finish assembling it.
