Picture of Bottle Case
PET is a type of plastic used for making bottles for different drinks. After using a bottle is necessary to recycle or converted. An excellent example of conversion of plastic bottle designed by the Austrian designer Zitta Schnitt: from the bottom of plastic bottles produced a purse!
Step 1: Materials, tools and accessories
Picture of Materials, tools and accessories
Plastic (PET) bottles (for making purses requires two plastic bottles. Showed Fri pouch is made from the bottom of two bottles of capacity 1.5 l. The remaining Dispose of plastic bottle recycling.)
-Zippy
-Needle and thread
-scissors
-sharp knife
-A template for drilling holes
-Scotch tape
Step 2: 2nd On the bottle set the template for drilling holes
Picture of 2nd On the bottle set the template for drilling holes
On the bottle is necessary to drill holes to facilitate sewing zipper (smi ka, "zipper"). The holes should be drilled at equal intervals in the same plane, which can easily be done using a template (pattern).
A simple template can be found at the end of this project. Download the template, print it, cut a strip of the template and carefully stick the tape on the bottle.Pa~ljivo promotrite dno boce. Iznad „krune“ uo it ete tanku crtu nastalu u procesu proizvodnje boce. Ta je crta idealna vodilja za postavljanje predloaka za buaenje rupica. Rub predloaka polo~ite uz spomenutu crtu, omotajte ga oko boce i pri vrstite ga selotejpom.
Debljom iglom za aivanje na plasti noj boci izbuaite rupice za konac. Rupice buaite na razmaku od 5 mm.
Step 3: 3rd Drill holes in the bottle
Picture of 3rd Drill holes in the bottle
Thicker needle stitching drill holes through the template attached. At the same drill holes on another bottle.
Step 4: 4th Cut off the bottom of the bottle
Picture of 4th Cut off the bottom of the bottle
First bottle carefully with a sharp knife make a cut right to the edge of the template.
Step 5:
Picture of
Through an opening made insert scissors and cut the bottom of the bottle.
Step 6:
Picture of
Prepared for the parts bag.
Step 7: 5th Prišijte smičak ;o)
Picture of 5th Prišijte smičak  ;o)
For sewing zipper prepare solid thread, because I had just an ordinary thread, I have used four or end.
Step 8: 6th Almost five case
Picture of 6th Almost five case
dr_peru17 days ago
Nice!
So cool! I have to make this...
amerari2 years ago
creative!!!
http://web.stagram.com/n/anamerari/
Mr.19113 years ago
Great idea, 5 stars!
verdastel3 years ago
Very good idea and explained with clear pictures. thanks for sharing!
kz13 years ago
This one goes in the favs
farzadbayan3 years ago
Nice, and nicer with a bigger first image.
imjasonc3 years ago
great idea to reuse bottles!
urtlesquirt3 years ago
Hmmmmmm... Looks misteriously like something from an issue of MAKE Magazine I have...
profpat3 years ago
great idea! hooray!
hadiarab3 years ago
hi
very good idea! thanks!
STFU.!3 years ago
COOLIO bro nice to know (bottle btw) :D
batonas3 years ago
this thing needs two speakers and you have a portable sterio saund system, I would call it bottle bass :D
randofo3 years ago
I think you meant "Bottle Case"
artworker3 years ago
Looks super cool! very futeristic! Good use of recycle!
zazenergy3 years ago
Awesome idea! Thanks for sharing!
Browncoat3 years ago
There are some English errors, but you did a good enough job that it is still very understandable. I love this idea! Thank you for sharing it! :)
