Remove these ads by
Signing UpStep 1Materials
*Old plastic bottles (esp 1 liter ones...they have a bigger surface for more butterflies, but any bottle with straight sides will do)
*Push pins (thumbtacks)
*A piece of wood that you are able to push the thumbtacks into
*Acrylic paint
*Sandpaper (220 works best for me! :D)
*Polymer clay (browns and blacks mostly)
*Strong glue (I have used hot glue, but it doesn't seem to be strong enough. I suggest gorilla glue or some kind of epoxy)
*Paintbrushes
*Sharp scissors or an exacto knife
You only sorta need:
*Clear spray varnish (preferably oil-based)
*Pearl Ex-which is a mica-based powder that makes the wings shimmer!
*Black wire
*Small black seed beads
*Gel acrylic medium (matte)
If you are willing to make these for custom order, contact me with the price.
Good work girl
http://www.instructables.com/id/Homemade-Belt-No-sew/
thnks
I found some old concrete pieces that were originally used to feed mink at a mink farm and since they're too shallow for a bird bath, I immediately thought of using them as butterfly baths. They are sort of petal shaped and have a bit of a shallow dip in the center that will hold liquid. I plan to mount the mink feeder on top of an old lamp base and wanted to decorate it a bit with a butterfly or two, but hadn't found any recycled butterfly decor. Yours will be perfect for my project!
Very artistic...nice reuse of materials and a well done instructable!
Keep in mind that acrylic paint can fade when exposed to a lot of sun...I'd recommend either using a paint recommended for outdoors or using a UV resistant sealant. (I'm pretty sure you can get spray-on varnish with UV protection, but if not just get a can of it and brush it on. Don't get water-based; it wont last long outside!)
Hope it works well for you!
