Step 1: Collect bottle caps.
-Become friends with bartenders.
-Cheap date night: Visit alleys behind local bars.
-Buy microbrews based on how cool the caps are, not how good the beer is.
-Get your friends to help you collect.
-When traveling overseas, buy beer instead of souvenirs.
Step 2: Find the table.
We used a Noresund IKEA table purchased in the As Is area at our local IKEA. I believe it is now discontinued. Sorry.
Link to Ikea store: http://www.ikea.com/ca/en/catalog/products/10073835
Step 3: Lay out your design.
Step 4: Begin gluing.
Since we were covering our table with clear resin, we weren't too concerned with the type of glue used. I started out with contact cement, moved on to furniture glue, then Liquid Nails for small projects, and even tried siliconized caulk. I ended up using plain old super glue. This was the best option and the one I suggest for you. Since the caps are going to get covered with resin, they just need to stick to the table, so a couple of dots are all you need. Don't go crazy, because messy excess glue will show through the resin when you're done.
Extra information regarding this step:
Although I suggest super glue for this project, the contact cement was truly the strongest adhesive. However, it took some time to use and was less forgiving. The silicone-based glues (Liquid Nails and caulk) seemed to shift or expand as it dried, which ultimately threw our design off. Super glue was the least elegant choice, but it dries relatively quickly and was rigid enough for this project. One note of caution: I discovered that Super Glue reacts with the hexane/toluene base of contact cement. They discolor and create a crystalline growth that resembles a fuzzy, white mold that must be removed with acetone. So pick one glue and go with it to avoid this kind of situation.
Step 5: Prepare your surface.
Don't forget to also tape up any holes on the surface of your table. I did this from underneath so that the blue tape wouldn't show once the resin was applied. If you have a table surface with lots of openings (like a metal mesh or expanded metal), you may want to get a piece of Plexiglas or MDF and use that for your tabletop.
Step 6: Build a barrier.
6a. I decided to use aluminum foil and duct tape. First, cut some long strips of duct tape to go around the edge of the table. Next, cut strips of foil about 3" wide and 1" longer than your strips of duct tape. Laying the strips of duct tape sticky side up, carefully cover about half of the duct tape with a strip of foil. See photo for details. The straighter you do this the better. You could also do this with wide painter's tape and eliminate the need to cover the edges of the table with painter's tape in Step 5.
6b. Tape the foil/tape strips around the edge of the table, making sure that the bottom edge of the foil falls just below the surface of the tabletop (the actual table, not the bottle caps). See photo for details. The reason: If the sticky surface of the duct tape is above the tabletop, the resin will stick to it and defeat the purpose of making an easy-release barrier. If the foil is too far below the tabletop, resin may seep over the edge, trapping blue tape underneath.
Step 7: Cover with resin.
Remember that the resin will level itself out, so just make sure you have enough to fill in the gaps and even out any high areas. You may want to cover your work to keep any random hairs or dust from getting stuck. Now walk away for about 7 or 8 hours.
Visit Our Store »
Go Pro Today »
My email is lunalunera19@hotmail.com
anyhow thank you so much for the tutorial. i will sure make a lot of tables like this once i get my hands on the resin. : )
Now I just need to collect bottle caps. OOOO Maybe Guitar picks would be a good substitute.
My biggest tips:
*use clear super glue only..anything else (gorilla glue, etc.) WILL expand and show.
*keep a pair of pliers handy in case you need to slightly bend the caps to fit the table towards the end when space is limited.
*Work from the outside in...otherwise you will run out of table space.
*When pouring the resin, use NON-STICK foil (higher quality the better..I used cheap stuff and that resulted in LOTS of left over foil scraps when it came time to peel away the barrier).
*Hold you hair back when you pour the resin/blow the air bubbles...I got some in my hair and it would not come out.
*read the instructions on the resin label multiple times
Cheers!
Witty AND informative :)
I used this guide and the table came out looking great; all except the edges. The foil is stuck along the rim (since the table doesn't have its own rims, I had to do the pour with the suggested foil barrier). Also, the top most edge of the resin pour extended a bit more then the base of the resin. Because of that, the top edge is a bit sharp. I obviously need to sand down the whole edge, but are there any suggestions or specifications I should be aiming for. like grit? I want to keep the edges clear, but I want to get the foil off and smooth the edges.
Any suggestions are welcome!
On the second page of comments, there were some posters who gave some more technical advice. One of them wrote:
"Carefully sand it to the shape you want, leaving a little extra "meat". Then, using finer grit sandpaper, work your way up to 1000 or 2000 grit sandpaper, followed by plastic polish to restore the gloss finish." I think a SUPER fine grit sandpaper would knock the edges down and leave a shine, but I've never done it, so experiment first.
Otherwise, search the web for info on how to shape the resin after it's set. Let me know what you find out!
The benefit to polyurethane is that it's cheap, you can just spread some on in a not too thin layer with a brush and move the caps as necessary, it dries in a reasonable amount of time, and you don't have to worry as much about mess. Polyurethane is the same thing gorilla glue is made out of, so it will definitely hold. If you're worried about the slightly yellow color (e.g., if your background color is white or light wood), use polycrylic instead, just make sure that it is all covered and can't get any moisture on it (it discolors).
If you can keep the hot glue "strings" under control and minimize the amount of excess around the caps, I think hot glue would work just fine for this project. Thanks for the suggestion.
And p.s. I'd say that table was made in Colorado, am I right?!
But they sell it other places though. I'm in Georgia right now and the liquor store across the street sells it.
the comments say 3 different states tho.. mebbe CO was one of em, eh ;)
