3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bottle Cap Table with Poured Resin Surface
We've been collecting bottle caps for what seems like forever anticipating this table. After moving our collection with us to 4 different homes in 3 different states, we now have enough caps for this table plus a few matching stools. What makes this project different than a simple mosaic project is that we covered the table with a thick resin, creating a look quite similar to the tables at your favorite pub.
Step 1Collect bottle caps.
Tips:
-Become friends with bartenders.
-Cheap date night: Visit alleys behind local bars.
-Buy microbrews based on how cool the caps are, not how good the beer is.
-Get your friends to help you collect.
-When traveling overseas, buy beer instead of souvenirs.
103 comments
1-40 of 103next »
Apr 28, 2012. 7:04 AMlunalunera19 says:
I couldn't download the pdf . Somebody can help me to have it?
My email is lunalunera19@hotmail.com
Aug 23, 2011. 6:06 PMhswartzloff says:
Any ideas where I can find the Resin? I live in a small town and wal-mart doesn't have it. I might need to make a trip to the city.....
Apr 22, 2012. 9:59 AMallenamistral says:
If you're still looking for the resin compound, you can check out dick blick. They sell art supplies online. Here's a link to the resin I use: http://www.dickblick.com/products/castincraft-clear-polyester-casting-resin/
Aug 25, 2011. 5:00 PMaspradlin says:
You would have to visit your local home improvement store or art supply store. My guess is that the resin will be cheaper purchased from a Home Depot type store.
Dec 21, 2011. 5:52 AMdfpowell says:
In Cincinnati, OH - I have found the envirotex lite at both Michaels and Hobby Lobby.
Mar 8, 2012. 9:16 PMmattthomas992003 says:
"-Cheap date night: Visit alleys behind local bars." prolly not a good first date idea
Feb 9, 2012. 9:21 AMjimbo13 says:
You can get a good epoxy resin on ebay, i would spread 1 layer and set the caps in it, then after it sets cover with the amount needed.
Oct 23, 2011. 8:05 PMStanleyHudson says:
Hypothetically speaking... if this table was for sale on craigslist what would you pay for it?
Jan 24, 2012. 6:46 PMtimweaver17 says:
dude, that is awesome!
Dec 21, 2011. 8:17 AMdepotdevoid says:
Hi, I just wanted to say thanks, when I went to build my Starry Night mosaic table, I thought of your project.  We used resin to cast the top, and it turned out great!
Dec 19, 2011. 4:46 PMtmisner says:
I'm building my own table and was thinking about putting a wooden border on the side instead of using the aluminum foil (seems like it gets too messy) how high would you recommend pouring the resin? Its going to be a 8x2 table and I was thinking 1/4 in of resin would suffice.
Nov 19, 2011. 8:46 AMkma akrim says:
oh now i know the name of this thing. a few years back, i saw a decorating program on television and was very amused with the designer's project for the house. he put a few small toy cars on a bar table and pour something to cover the cars. when it was set, it became just like your table! i've been wondering all this time of what is that liquid and where to find it. now i know, but still i don't where to get it. stuff like this is hard to find here in my country.
anyhow thank you so much for the tutorial. i will sure make a lot of tables like this once i get my hands on the resin. : )
Nov 4, 2011. 4:12 PMabitdifferent says:
Does anyone know where I can get this resin? I'm in the UK and I use epoxy resins for roofing but its a matt finish, somebody must know of somewhere i can get a clear glossy finish resin cheers
Jul 2, 2011. 2:31 PMpyromonkey says:
This is so awesome! I have the perfect table to do it to as well :D
Now I just need to collect bottle caps. OOOO Maybe Guitar picks would be a good substitute.
Jun 22, 2011. 10:32 AMskowatch says:
Alright I just finished mine, it turned out great.
My biggest tips:
*use clear super glue only..anything else (gorilla glue, etc.) WILL expand and show.
*keep a pair of pliers handy in case you need to slightly bend the caps to fit the table towards the end when space is limited.
*Work from the outside in...otherwise you will run out of table space.
*When pouring the resin, use NON-STICK foil (higher quality the better..I used cheap stuff and that resulted in LOTS of left over foil scraps when it came time to peel away the barrier).
*Hold you hair back when you pour the resin/blow the air bubbles...I got some in my hair and it would not come out.
*read the instructions on the resin label multiple times
Cheers!
Jun 22, 2011. 10:33 AMskowatch says:
not sure if the images worked...
Jun 14, 2011. 9:51 AMskowatch says:
I followed this step exactly however found that the foil stuck to my resin all around after peeling it away. Using a craft knife to chip at it was slow, tedious and messy. Any other advice?
Jun 19, 2011. 4:11 PMtobster9103 says:
You could try the non stick kind.
Mar 28, 2011. 8:22 AMFuzzyBearGeek says:
"When traveling overseas, buy beer instead of souvenirs."
Witty AND informative :)
Mar 14, 2011. 7:39 AMbruiz826 says:
I need help with this instructable please.
I used this guide and the table came out looking great; all except the edges. The foil is stuck along the rim (since the table doesn't have its own rims, I had to do the pour with the suggested foil barrier). Also, the top most edge of the resin pour extended a bit more then the base of the resin. Because of that, the top edge is a bit sharp. I obviously need to sand down the whole edge, but are there any suggestions or specifications I should be aiming for. like grit? I want to keep the edges clear, but I want to get the foil off and smooth the edges.
Any suggestions are welcome!
Oct 28, 2009. 7:20 PMMaryLenehan says:
 I was thinking about doing a project like this, and considering hot glue to secure the caps. Did you reject this approach for some reason? Mess?
Mar 3, 2011. 1:35 PMdebbieorah says:
I tried edging a mirror in bottlecaps, and when doing that i tried hot glue and superglue. THe hot glue popped right off pretty much right after adhering to the mirror for a minute. (not sure if there would be a different result if it wasn't sticking to glass). Can't wait to try this in table form and use the resin... im hoping for a funky and cool piece like that!!! A+ job americangypsi!!!!!
Oct 29, 2009. 8:25 PMDMBillies says:
 Cool table.  In college I made a 5' x 7' beer pong table covered with caps.  Needless to say I was working on a much bigger surface.  Had a friend that could do the covering of the caps with fiberglass resin for free (which was great), but we used polyurethane to do the initial gluing down of the caps (aside from the sliding issue, caps will try to float... so let me reiterate what the poster said... don't skip this!).
The benefit to polyurethane is that it's cheap, you can just spread some on in a not too thin layer with a brush and move the caps as necessary, it dries in a reasonable amount of time, and you don't have to worry as much about mess.  Polyurethane is the same thing gorilla glue is made out of, so it will definitely hold.  If you're worried about the slightly yellow color (e.g., if your background color is white or light wood), use polycrylic instead, just make sure that it is all covered and can't get any moisture on it (it discolors).
Dec 20, 2010. 11:42 AMginarina427 says:
what an awesome table! going to try doing this with 'built in coasters'
Oct 10, 2010. 8:28 AMLilithAvalon says:
Nice. I'm thinking of doing something similar, with a collage mod podged on. How much resin did you use? Should we be looking at gallons or something smaller?
Jan 10, 2010. 11:25 AMTim1252 says:
Check this out! It's not my car, I've seen it in Grand Canyon National Park (North Rim). It were plastic caps and they were glued with silicone.  How long would they have been gathering.
Oct 6, 2010. 8:16 AMDoofus89 says:
that is awesome!!! XD
Feb 9, 2010. 10:16 PMBarginsTech says:
what the faux!!! HOLY COOL! lol love the table! deff gonna make one but oh man imagine that as my CAR! 8D
Sep 15, 2010. 11:44 AMsparkuhlism says:
That car is AWESOME.
And p.s. I'd say that table was made in Colorado, am I right?!
Sep 25, 2010. 8:02 AMWobot says:
I was wondering what made you say it was made in CO, and then I saw: Left Hand beer!
But they sell it other places though. I'm in Georgia right now and the liquor store across the street sells it.
Sep 28, 2010. 2:43 PMsparkuhlism says:
whoah no way! im in las vegas and I have to have it special ordered at my liquor store.
the comments say 3 different states tho.. mebbe CO was one of em, eh ;)
May 10, 2010. 11:59 AMelcamino1979 says:
I'm making a 7x3 table. How much resin do you think I'll need? And are there any suitable alternatives to Envirotex Lite?
Aug 5, 2010. 2:29 PMpgheit01 says:
The resin kit you buy will tell you how much surface area it will cover, and at what thickness.
Jun 27, 2010. 7:28 PMApple_4_life says:
awesome!! now make some chairs to go with it!
Feb 25, 2010. 11:24 AMDescon says:
I love the ring of newcastle caps, mmm newcastle!
Nov 6, 2009. 4:36 PMallmondjoy87 says:
 made a beer pong table featuring our mascot using the same stuff.  (sorry no instructable just final product)
www.pix8.net/pro/pic.php
Feb 9, 2010. 10:17 PMBarginsTech says:
WOAH SICKKKK!!
Nov 11, 2009. 2:03 AMGrey_Wolfe says:
Nicely done.
1-40 of 103next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
31
Author:americangypsy(AmericanGypsyLiving)
