Step 6Build a barrier.
6a. I decided to use aluminum foil and duct tape. First, cut some long strips of duct tape to go around the edge of the table. Next, cut strips of foil about 3" wide and 1" longer than your strips of duct tape. Laying the strips of duct tape sticky side up, carefully cover about half of the duct tape with a strip of foil. See photo for details. The straighter you do this the better. You could also do this with wide painter's tape and eliminate the need to cover the edges of the table with painter's tape in Step 5.
6b. Tape the foil/tape strips around the edge of the table, making sure that the bottom edge of the foil falls just below the surface of the tabletop (the actual table, not the bottle caps). See photo for details. The reason: If the sticky surface of the duct tape is above the tabletop, the resin will stick to it and defeat the purpose of making an easy-release barrier. If the foil is too far below the tabletop, resin may seep over the edge, trapping blue tape underneath.
comment
Add Comment
tobster9103
says:
Add Comment
