Bottle Incense Burner
Turn any decorative (i use wine bottles) bottle into an ashless incense burner. With less than seven dollars worth of diamond chip dremel bits, you can drill a hole to allow airflow in a nice bottle without shattering the glass.
Wear a dust mask, cause' glass powder isn't good for the lungs. Eye protection is always a good shot too!
Step 1Pick a Bottle
Pick a Bottle
Pick a bottle that you would deem fit for an incense burner. Get a Dremel tool (if you don't already have one) and a cheap box of diamond chip bits from a flea market or some cheapo store.
Check this size bit. I choose this shape to go in at a slight angle so it is more like you are digging out the glass
rather than wildly spinning through it like on a drill press or the like.
23 comments
Jan 8, 2012. 10:04 AMoking says:
A split ring is easier to work with.
The diamond tool is just one method. Most hardware store sell a glass bit for a drill. I've used it with acceptable results. The method being shown here look much better and I bet the tool could be used to engrave the glass later.
Apr 13, 2011. 7:06 PMsillyzombie666 says:
i still want to make one of theses but have yet to get the drill bit
Dec 31, 2010. 10:41 AMbigbubblesoap says:
Decorative paper clips in various designs also works to hold incense. I found mine at an office supply store. They may come in a box of 12, so that is enough for everyone on your gift list.
I also thought of decorating the bottle with glass decals, better yet, maybe some glass etching designs using etching paste.
Feb 9, 2010. 7:31 PMheadlessbubble says:
I made this and absolutely love it! thanks for sharing great instructable!
Jan 11, 2010. 6:29 PM.happy.hippie. says:
putting the end of the incense into a keyring that doesn't fall into the bottle is what i do
Oct 18, 2007. 3:25 PMjspyrogram says:
I made one of these. I couldn't get the incense to stay lit even though I made 4 holes around the bottom about an inch and a half up from the bottom of a tall coke bottle. Any have any ideas what I may have done wrong?
Dec 5, 2009. 8:03 AMdaxdrone says:
hey jspyrogram, I just started making these myself and the same very issue. I tried a more "true" incense as WUVIE suggested. That didn't change the out come. What I did was but a series of holes vertically one the bottle. I did 3-4 holes about an 1 inch to 2 inches apart(depending on the size of the bottle) using 1/4 inch diamond drill bit. I found that three work best, because the bottle filled with smoke which looked really cool. This is what has worked for me. Now all my friends and coworkers want one, this is a great and fun project.
Jul 18, 2009. 12:36 PMWUVIE says:
Hello Jspy, it may not have been the bottle, but your incense. Many of the incense sticks sold at convenience stores, box stores, etc. are not worthy of burning, won't stay lit, and don't smell good at all. Shopping malls and smoking stores often carry Nag Champa, Super Hit and other true incense. When you buy incense, it should be fresh, with a seal even better. :-)
Jul 3, 2006. 9:36 PMtheRIAA says:
why hold it? just let it drop
Oct 25, 2007. 5:06 PMtheRIAA says:
put sand in the bottom?
Aug 15, 2009. 7:35 PMJ@50n says:
Sand and flame don't mix to well.....
Jul 5, 2006. 3:34 PMleevonk says:
you could maybe drill a thin hole lengthwise through the bottles cork, and stick the base of the incense into it each time. squishy property of cork should make it easy to stick in and take out the incense, and it would look a lot better.
Jan 27, 2009. 7:00 PMWUVIE says:
Imagine this! I have been searching for an Affentaler bottle for years, as well as always wanting to make one of these nifty incense holders. So here I sit looking up an Instructable, lo and behold you have both in one! Way cool! Off to Ebay to search for Spatburgunder once more! Karen Marie
Jan 13, 2008. 3:33 AMseanhexed says:
Another good way to do the incense hanging bit on these is to use a treble fishing hook (the ones with three prongs) that's large enough for the prongs to fit around the top of the bottle. Then clip the points & barbs off, file the ends all nice, and pinch the flanges of the alligator clip around the part of the hook where you'd tie the fishing line. It's nice because it can't drop in and doesn't restrict airflow.
Nov 16, 2007. 7:09 PMtheking says:
SWEET
Jun 29, 2007. 11:44 PMstonebrew says:
Just a little advice. Fill the bottle up with water, submerge under water in your kitchen sink and then start drilling. This works great in helping to keep the glass and drill bit cool. Heat from the friction is one of the main causes of the glass breaking.
Jan 1, 2007. 4:04 PMmacher00 says:
I've used a bit made for drilling ceramic tile to do things like this.
Oct 7, 2006. 8:57 PMzjgz says:
my dad used to do the same things with wine bottles, you could also use an arizona tea bottle, and since the neck is wider on those bottles you don't need to drill any holes
Jul 3, 2006. 11:27 PMMargART says:
this is way cool. funny thing is, my mom actually bought one of these for me.
Jul 3, 2006. 9:37 PMAnimalChin says:
A few years ago I tried making these with a "glass cutting" drill bit. The experiment resulted in 7 or 8 broken bottles. Glass cutting bit my ass!
The diamond bit makes all the difference. I just made 2 of these in less than 10 minutes.
Remember: rotary tools work on speed, *not* power. Don't try adding too much pressure to the bottle, and make sure your bit doesn't stray and you'll have a perfect hole when you're done - instead of scratch marks and dents like mine.
Excellent Instructable.
Jul 3, 2006. 9:38 PMAnimalChin says:
Also: A dime-sized is probably overkill. A quarter-inch should be plenty.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fleanine
