loading
Step 5: The Parachute
Next is the parachute. This is what the painter's drop cloth is used for. First, fold the drop cloth into a square and then cut it. Once it's in a square you want to fold the drop cloth in half, and then in half again about 3 more times. It should look a bit like a long triangle at this point. Cut about a foot off only on the bottom (NOT the pointed top). Unfold it and it should look like a circle. Keep re-folding and cutting until the diameter is about 54". This seemed to be the perfect size for a parachute. After you have reached the desired size, place little squares of tape on the ends of the parachute 8 times. Punch holes and then tie 54" strings in each hole. This is your parachute.
<p>Good question....</p><p>How does the 'chute deploys?</p>
<p>the person who &quot;invented&quot; this how does the parachute come out and is it one time use or</p>
&nbsp;How does the parachute deploy? Does the wind catch those plastic tabs when the rocket is falling down and pull off the nose, thus releasing the chute?
About This Instructable
42,639views
14favorites
License:
More by haleyanna:Bottle Rocket How To
Add instructable to:
