Remove these ads by
Signing UpStep 1Hardware:
2)Scrap wood, bamboo sticks, PVC or similar for frame.
3)Wood screws.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
My point is that ideally the surface treatment will not be porous.
The surface treatment is not porous.When you decoupage using paper or fabric it is sealed with a sealant like mod podge.Give it a couple of coats at least. If you are leaving it out in the sun, use outdoor podge. Use polyurethane after the podge coating if you want a stronger sealant .Please wait for it to dry completely between coats. It is now water proof .
As for how often I water - depends on the plant.When you feel it's drooping, leave the container in a bowl with water coming a little above the hole on the side. Water will seep in through the hole .
I did sent an instructable with pictures explaining the method but it doesn't seem to have gone thru. Will try once again.Meanwhile I hope this makes sense.Please read my comment given on April 3,2011.
Actually the plants in this instructable are also going to be root bound, but such are the tradeoffs one makes using what containers are available and you can just use more containers for more crop yield. With some it won't matter as much, for example cilantro will bolt in only a couple weeks of warm(er) weather so you want to harvest it before that happens and changes the flavor of the leaves, meaning it doesn't get a chance to grow very large in warmer climates. It likes to grow deep roots though so ideally more of the length of the pots would be left on when cutting the bottles.
Forgot to mention that my next project is hanging pots with two litre bottles. Similar to the ones shown in the picture, but each bottle to be slipped into a bag with a draw string gathering the bottom part round the narrow mouth of the bottle and a handle on the wide top. Plan to hang them from my balcony rail. Shall try Strawberries this time !!!Thanks for the idea
CDfolia
I have also found that using the bottle caps instead of stones to stop the water from washing the soil out works really well too!
I live in a major city and have a tiny space for gardening so was looking for a good method of making a vertical garden.
I'm thinking I'm going to try and cut the bottom off the mismatched socks I have in my laundry room and stretch them over the bottles to shade the roots. Hopefully they won't be too tight and "squish" the bottles.
Nice instructable! Thanks for sharing!
