loading
Step 8: Modify Porcelain Socket
In this step we modify the metal (female threaded) bottom piece of the porcelain socket. As you can see in the pictures, we want to remove half of the metal shaft that attaches to the bottom of the porcelain socket. This will allow our cord to exit sideways through the 1/4" hole we drilled toward the bottom of the lamp base.
NOTE: This step is optional. If you do not feel comfortable performing this step or do not have the tools to cut the metal shaft, you can leave the socket as designed and the result will be that your porcelain socket will stick up an additional 1/4' from the top of the lamp base. The original design has the socket approximately 1/8" above the top of the lamp base. Without this modification your socket will stick up to about 3/8" above the lamp base.
NOTE: You MUST use the ceramic washer and metal bottom of the porcelain socket and cannot simply leave it off as it insulates the bare electric wires.
Begin by removing the metal from the porcelain by removing the 2 screws deep inside the socket where the bulb is screwed in.
Next hold the metal piece with a pair of pliers or vice and, using a Dremel with a cutting disc, cut away half of the shaft. Take care to do it neatly so you do not leave any sharp jagged pieces of metal as you do not want to cut your electrical cord on anything sharp.
File the remaining socket if it is not smooth. Then reassemble the socket and set aside.
<p>Thanks,this is a good one,it gives me some ideas.</p>
Great ible, great lamp. minor correction (and i googled it to be sure cause i wasn't certain myself). The flat bottom drill bits are forstner bits.
Thanks so much for catching my typo. I updated step 7. Please let me know if you saw it incorrectly referenced anywhere else. Thanks!
I think there were a few picture references that had it too.
Nice lamp. <br>Great ible. <br>An excellent excuse for the house smelling of bourbon.
Would this instructable work with Rye whiskey??? <br> <br>Kidding, of course. A well-crafted 'ible and a beautiful end product. Cheers!
it's great. I have a lot of empty bottles - now I'll know what to do. Just registered on the site - very pleased. Thank you!
This is so fancy. Love the way the lamp looks, and it smelling like bourbon is a welcome plus. :D
About This Instructable
13,394views
85favorites
License:
Bio: I'm a maker and love building things using 3D printer, wood, metal, software, microcontrollers, fabric and other materials. I love to use creativity to ... More »
More by matthewtmead:C-Clamp Wood Shelf Pipe Wrench Table Hockey Stick Bench
Add instructable to:
