Fancy Wooden Toilet Stool
Introduction: Fancy Wooden Toilet Stool
Pooping: you're doin' it wrong! Apparently "squatting [is] a more natural position that opens the anal sphincter, moves the body's plumbing into proper alignment, and allows us to evacuate more freely." Considering billions of people in Asia still do it this way, and all human beings did it for all most all of our existence, it seems like a good argument. Just look at the sciency diagram!
Instead of buying one of the molded plastic ones that look like a cheap medical industry product, I decided to make something out of hard wood that I might actually want to look at. If it's going in my house, it better be classy.
Step 1: Design
As usual I'm using Fusion 360 for this project because you can easily work simultaneously in 2D and 3D, and the parametric features really help when you're going through a lot of design iterations. Fusion has a free 30 day trial after which you can choose to continue as an "Enthusiast" with a free non-commercial license for 1 year. After that, it's $40 a month for a professional license, which is absurdly cheap for a design program this powerful.
I based the dimensions of this stool (no pun intended) on a friend's off-the-shelf version. The foot holds are at about a 5º angle, and it measures about 20"W X 9"H X 12"D. There's a u-shaped cut-out on the top so that you can store it against the toilet when it's not being used, and I added arcs to the bottoms of the side boards to act as feet.
There's a "beam" along the front for lateral stability. I filleted the corners because I wanted to keep the arc motif that you see in the rest of the piece.
If you want to save $10 on the large format printing, you can print and tile the 8.5 X 14 PDF file on a desktop printer using Legal sized paper. NOTE: all printing must be done at 100% scale. Do not use any kind of scaling, such as "fit to page size", when you're printing the templates, no matter what kind of warning your program gives you.
Step 2: Tools & Materials
I used 3/4" poplar for this project because it's a hardwood and it's easy to find at any hardware store. It will sand to a fine finish, which is important for ease of cleaning, and it will make for a sturdy finished product.
First, I edge-glued two 10" wide planks to make a monolithic panel. I cut out the parts on our Water Jet because it's fast and accurate (and we have one), but you could easily cut out these parts with a jigsaw using the Digital Fabrication by Hand technique in my previous instructable.
After the parts are cut out, all you need is a palm sander, clamps, wood filler, and some wood glue. I chose to finish mine using several coats of butcher block oil, but using a high gloss polyurethane or some other slick finish would probably be a good idea- the key here is that it should be easy to clean!
Step 3: Glue & Clamp
First, I clamped the legs onto the foot board. Corner clamps are great for ensuring that you get consistent right angles, and I added a pressure clamp in the center to make sure there was solid contact between the surfaces.
You could use biscuits or dowels in this step, but it didn't seem necessary to me because there's no end-grain gluing.
Once the sides were cured, I added the beam with the filleted ends to the center of the font edge. This is here to add a bit more stability to the foot board and keep it from bending.
Next, I added come 3/4" X 3/4" scrap pieces to the inside corners on the sides to help keep the stool from flexing sideways.
Step 4: Finishing
Once all the glue was cured, I filled in the handful of cracks with stainable wood filler. Once that cured, I sanded the whole piece down to about 220 grit. This left a smooth surface that is easy to clean- no rough spots or splinters to snag the cleaning cloth.
When the sanding was done, I applied 3 coats of butcher block oil with several hours between each coat.
Step 5: Finished Product
I won't go into the intimate medical details, but it's safe to say I'm never going back to pooping the wrong way.
3 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
Awesome stool. I really want to make this! When I download the last PDF how can I check to see if it's scaled to 100%? No where on adobe is it giving me this option. I just tell it to print and that's it. Another problem I'm facing is I don't have legal paper. Is there a way to get this to work using normal 8x11 sheets of paper?
When you print the file, you should see a "scale" option somewhere on the dialog. If you do, that should be set to 100%. Make sure you don't check "scale to fit media". If there's a box that says "original size", check that and it's the same thing as making it 100% scale.
I just uploaded an 8.5X11 layout to the same step. Good luck!
Could you post the dimensions of each piece?
I found this design on the Squatty Potty site. Do you have a suggestion on how to construct something similar? I really like the adjustable design.
I would do it something like the image below. Slots and tabs will make it easy to adjust and easy to fabricate. Have you downloaded Fusion 360? This would be a good project to start learning 3D with I think.
Would it be possible to print these on a standard printer and piece them together in some fashion? My local printer is asking nearly $10 to print.
You could print it in a smaller format and tile the pages together. Adobe Acrobat can do that I think.
Sounds, wouldn't that require a paid version of Acrobat? Is a method/download to print this from a typical home printer something you could offer as an additional option?
Trying to keep this whole thing affordable and less than what I would pay for a real squatty potty.
I've added a multi-page PDF of the layout to Page 1 that you can print on legal sized paper (8.5 X 14). You should be able to print these out and tile them together using tape. Note: DO NOT print them using "fit to page size" or any similarly worded setting. They must be printed at 100% scale, even if you get a warning that the printer will crop part of the print.
