+Bow - Homemade Spring-Powered Nerf Rifle
Specifications
Length: 36 inches
Weight: 2lb
Plunger load: 18-32lb
Spring load maximum: 38lb
Optimal Barrel Length: 12 inches
Performance
Plunger rod has three notches affording different load rates which gives the user different range options.
Distances averaged
28lb Pull: 140 feet
22lb Pull: 110 feet
16lb Pull: 80 feet
Individual results will be dependent upon too many factors to list so take these only at face value.
Tools REQUIRED for following this guide
+ Scrollsaw
+ PowerDrill or Drillpress
+ Mitre Box & Mitre Saw or a power tool useful for cutting plastic rod or tube (such as a table saw, circular saw, or band saw)
+ #6-32 Tapping Bit
+ Screwdriver
+ Hobby Knife (to clean the edges of the sheets once cut)
+ Scissors
No other tools expressly needed. All tools listed are not easily substitutable and I don't recommend attempting to make this gun with anything other than a scrollsaw due to the size of the parts you will be making.
Part List
Download: plusbow_partlist.txt
Note: You will also need some full sheet label paper, electrical tape, and some spray silicone lubricant.
All items available through Mcmaster Carr
Simply search for the part #s listed. Total cost of supplies listed is around $80 plus shipping. You will have enough excess of most materials to make atleast 2 or 3 more guns.
Be warned. This guide has 37 steps. Not because the project is extremely complicated, but because I'm going to go into a good deal of detail on each step.
Step 1Step One
Step One
Download the cuttings template sheets: plusbow_templates.doc (100kb)
Print them on full sheet label paper. If you ran out of color ink (like I did) make sure to use a colored pencil to mark the holes with the size you will need to drill them to.
117 comments
1-40 of 117next »
Oct 7, 2011. 8:36 AMGreat Wight Ninja says:
I have been wondering this since I first saw the design on Nerfhaven about half a year ago. What makes it a bow? I mean, I've even seen plenty of "crossbows" that are little more than stylized slingshots, but they actually have a pseudo-bow to them. The Big Bad Bow isn't even really a bow. It's a stylized gun as well. But again, what makes this a bow?
I realize someone just decided to name it a +bow and the name stuck, but I was hoping you/someone could help shed some light on the rationale.
This will not, however, prevent me from making the effort to finally build one of these when I have time and access to the tools.
Jun 16, 2011. 6:59 PMMatthew1871 says:
i love it but i have to thing to say Coild there be like a site wear i can get those parts that ship to CANADA because Mc Master Carr only ships to US witch sucks or ill just wait 1 year till i go to us and then order the supplies plz HELP!!!
Jun 1, 2011. 10:26 PMarmored bore says:
In my vast engineering intellect, I think I cut my plunger rod a bit too short for the whole spring. Should I trim down the spring to fit it?
May 24, 2011. 2:26 PMarmored bore says:
Are those other rectangular components still required? I can't find them on the template document.
Oct 18, 2010. 7:39 PMnatester632 says:
How big should the paper be that you print the templates on?
Mar 22, 2011. 2:02 PMnatester632 says:
k thx :)
Nov 28, 2010. 6:06 AMtazer_trooper says:
it reminds me of a 50cal.
Oct 16, 2010. 12:16 PMKikot says:
waw where did u get that huge spring?
Sep 11, 2010. 7:35 AMjongscx says:
Wait... how do you load and shoot this thing? Is it just a muzzle-loader?
Jun 9, 2010. 3:10 PMpopscott3 says:
THAT IS SO COOL!!!
Apr 4, 2009. 12:22 PMGhost Wolf says:
where does the amo go? or is there a clip
May 26, 2010. 12:15 PMeleven-seven says:
how much was the plus bow to make?
May 26, 2010. 12:17 PMeleven-seven says:
could you, or do you know where i could find, a list of parts that i should get to make this
Apr 5, 2009. 2:03 PMGhost Wolf says:
ok thanks
Apr 27, 2010. 1:49 PMAirsoft Guy says:
 now i just need the petg plunger tube
Apr 20, 2010. 7:53 PMAirsoft Guy says:
 i just need the catch and k26 spring can i just buy those off you please
Apr 21, 2010. 6:48 PMAirsoft Guy says:
 i just suscribed man
Apr 21, 2010. 6:47 PMAirsoft Guy says:
 by any chance can you get a good catch spring replacement for a nitefinder i will buy the k26 spring to
Apr 18, 2010. 9:02 AMAirsoft Guy says:
 do you mean 2 to 3 more plusbows
Mar 18, 2010. 5:40 PMMAVREV13 says:
i ment ideas on moding it to look like one an ar15 armorlite.
Mar 15, 2010. 6:11 PMMAVREV13 says:
hey captainslug i need advice on makeing my recon look more liker an ar15 armorlite and im wondering if u could help me out. here it is
Mar 16, 2010. 1:03 PMMAVREV13 says:
thanks any way do u know any one that could help with makeing it more like one. oh nice mods i looked u up on youtube nice mods dude you are vary awsome im wondering how do u get your ideas.
also what is the farthest a modded recon can get with out
1 brakeing it at 2 shots or modding it to where people dont believe that it was a recon in the first place (crazy insain super mod)?
Mar 16, 2010. 5:12 AMzack attack says:
How much $$ did u sell it too uin13? ps: he is awsome.
Mar 16, 2010. 5:09 AMzack attack says:
HOW FAR DOES IT SHOOT WITH NORMAL DARTS!!!
ps( i didn't capitalize it to yell at u, i just wanted to get ur attention.)
Mar 13, 2010. 4:49 PMMAVREV13 says:
this is beast does this + = or get more range than a epic ls or nerf crossbow
Mar 14, 2010. 10:12 AMMAVREV13 says:
wow that is cool. also how long did makeing the first one take and did u alone make it or did u have help
Mar 11, 2010. 5:48 PMskaboy says:
 i'm interested in getting into this hobby and ive been looking at several homemades and i have to say yours is probably the most effective i have seen considering the simplicity of it.  kudos! I was wondering though, how hard would it be to modify your design to hold a clip or some kind of system that would allow it be fire semi-automatically?
Feb 12, 2010. 8:49 AMcrazyboy007 says:
 could you use a dremel to make the cuts needed?
great job by the way
Nov 3, 2009. 12:46 PMJimpiedepimpie says:
Awesum
But does it fire stock darts(the tagger ones) aswell?
1-40 of 117next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:CaptainSlug
