Specifications
Length: 36 inches
Weight: 2lb
Plunger load: 18-32lb
Spring load maximum: 38lb
Optimal Barrel Length: 12 inches
Performance
Plunger rod has three notches affording different load rates which gives the user different range options.
Distances averaged
28lb Pull: 140 feet
22lb Pull: 110 feet
16lb Pull: 80 feet
Individual results will be dependent upon too many factors to list so take these only at face value.
Tools REQUIRED for following this guide
+ Scrollsaw
+ PowerDrill or Drillpress
+ Mitre Box & Mitre Saw or a power tool useful for cutting plastic rod or tube (such as a table saw, circular saw, or band saw)
+ #6-32 Tapping Bit
+ Screwdriver
+ Hobby Knife (to clean the edges of the sheets once cut)
+ Scissors
No other tools expressly needed. All tools listed are not easily substitutable and I don't recommend attempting to make this gun with anything other than a scrollsaw due to the size of the parts you will be making.
Part List
Download: plusbow_partlist.txt
Note: You will also need some full sheet label paper, electrical tape, and some spray silicone lubricant.
All items available through Mcmaster Carr
Simply search for the part #s listed. Total cost of supplies listed is around $80 plus shipping. You will have enough excess of most materials to make atleast 2 or 3 more guns.
Be warned. This guide has 37 steps. Not because the project is extremely complicated, but because I'm going to go into a good deal of detail on each step.
Remove these ads by
Signing UpStep 1Step One
Print them on full sheet label paper. If you ran out of color ink (like I did) make sure to use a colored pencil to mark the holes with the size you will need to drill them to.
I realize someone just decided to name it a +bow and the name stuck, but I was hoping you/someone could help shed some light on the rationale.
This will not, however, prevent me from making the effort to finally build one of these when I have time and access to the tools.
also what is the farthest a modded recon can get with out
1 brakeing it at 2 shots or modding it to where people dont believe that it was a recon in the first place (crazy insain super mod)?
No, he is not awesome.
I don't do range tests with stock darts. With stock darts of any kind you're not going to get the kind of ranges or accuracy you would with homemade darts.
HOW FAR DOES IT SHOOT WITH NORMAL DARTS!!!
ps( i didn't capitalize it to yell at u, i just wanted to get ur attention.)
Heavily modified crossbows top out at 100 feet typically. But is most consistent up to 70 feet.
A well made +bow on average will reach up to 120 feet and is quite consistent up to 90 feet.
great job by the way
