+Bow - Homemade Spring-Powered Nerf Rifle
 by CaptainSlug
Step 11: Step Eleven
Using a mitre saw with box, table saw, table saw, or circular saw cut a 7/16" length section off of the 1" diameter plastic rod.
Using the 1/8" thickness plunger rod piece as a template (as centered as you can get it), mark the two holes as shown.
Using a 5/32" bit in a drill press or power drill drill through at the marked points.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
