3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
+Bow - Homemade Spring-Powered Nerf Rifle
Step 17Step Seventeen
Step Seventeen
Assemble the center frame piece and catch plate together as shown using washers and 1" length screws.
Attach the 12" length section of 1/2" diameter rod to the center frame piece using a 3/8" length screw. Mark on it where the centerline of the catch plate is.
Remove the 12" rod and using a 7/64" bit in a drillpress or power drill drill through where marked. Then tap the hole with a UNC #6-32 tapping bit.
Attach the 12" length rod to the rear frame piece again using a 3/8" length screw. Install a set screw into the newly tapped hole by hand.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:CaptainSlug
