loading
This is how I made my custom Bowie knife
Step 1: Design
The first thing that needs to be done when makeing a knife is always come up witha rough sketch of what u want it to look like
Step 2: The Blank
Cut out the blank for your knife
Step 3: Profile Work
Once you have cut out your blank you need to clean up the edges with a file. Then grind the bevel into the knife
Step 4: Heat Treat
After you put the bevel on the blade it is time to heat treat. To heat treat your blade you need to build a rough forge or fire that will get the blade hot enough. Once you have heated the blade so that it is glowing brightly you need to quench it in oil
Step 5: Clean Up and Handle
After the heat treat there will be black residue on the blade so that needs to go. Once that is done u must start the handle. There are many different way to make the handle but my favorite way is to take multiple kinds of wood and glue them to the tang. Once the glue dries I grind the wood I to the shape I want
Step 6: Finishing Touches
Once I have fished the grinding and I'm happy with how it looks I go over it with sand paper and put some wood finish on it
Step 7: Done
The last step is to just wait for the finish to dry and then u have a new knife
<p>Be careful with that you did not temper it so it is like glass.</p><p>(it is in a brittle state after heat treating so you temper it to relax it a bit)</p>
Ur welcome
Thank u
By the propper deffinition it is a hornet karambit
By the proper definition what is it.
While you're reading up on knives, read up on Bowie knives. This is not a Bowie knife by any definition.
Which part of it was not safe
As a disclaimer this I a instruct able for those with. Common spence on regular safety precautions and ice been makeing knives for five years this is just my first Bowie
The reason I didn't temper was because I didn't know how. I need to do research on it but ya. I'm used to makeing small fishing knives not Bowies.
It seems like you are new to knife making, I suggest that you read up on correct and safe procedures and revise your Instructable, we don't want any community member to get hurt. Good start
?? Why didn't you temper it afther quencing?
Cool! Thanks! <br>
About This Instructable
4,038views
57favorites
License:
More by jhowie103:Home Made Knife Bowie Knife Homemade Knife
Add instructable to:
