Step 2: Joining the bowls
- Put one bowl on the top of the other aligning them by the handles. Then use some masking tape to hold them together. Also glue the masking tape around the edge of the bowls to avoid them to move while working.
- Use the CD marker to draw a cross at the center of each handle. If your bowl doesn't have handles, please be creative!
- Use the Dremel with the small routing bit to drill a hole at each mark. You can also use a standard drill with a drill bit (yeap, it makes more sense to use a drilling bit to drill, but... nevermind.. just do the holes)
- Squeeze a ty-wrap at each hole (ok, wrap it!). Do it before start to drill the other holes to avoid disalignments.
- Wrap a metrick tape around the upper bowl to measure the lenght between the two holes.
- Divide the measurement by 3 and place a cross at that lenght away from each ty-wrap. In my case the distance was roughly 24 inches, and I have placed 4 marks, each was 8 inches apart of each ty-wrap (at the left and at the right).
- Drill a hole at each mark and put a ty-wrap at  each hole to firmly hold the bowls together..
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
