Step 4Drill the Balls
To drill the hole I loaded the ball into the rest, chose a spot that looked like it was in the center of the cut off portion and drilled. The first ball was no problem because I drilled a pilot hole. So I just applied frim steady pressure while drilling and the bit travelled straight through just like I wanted.
Next I stacked one ball on top of another making sure the edges of the cut off portions of the balls were aligned. I then passed the bit through the hole in the first ball and drilled a little divet to mark where I wanted to drill the hole. I removed the first ball and proceeded to drill the hole through the second ball. However, I had a bit of a brain fart and forgot to drill a pilot hole and apparently didn't keep the drill oriented very well. I ended up with a hole that didn't take a straight path. The angle was such that the tubing wouldn't be able to pass through both balls and maintain their alignment. To rectify this I drilled a second hole parallel to the first. I then used a ballpean hammer, a chisel and my masonry bit to remove the material between the two holes.
For the last ball I marked where I wanted the water to come out of the rounded top. I drilled a pilot hole and then followed it up with the masonry bit. This hole also went slightly off course. However I was able to rectify this less serious detour by simpling widening the hole on the bottom of the ball. I just drilled a second hole that intersected the first at a shallow angle, and then cleaned it up with a chisel.
Add Comment
