Box With a Secret
1,933
18
Published
Introduction: Box With a Secret
About: If you like simple solutions then here you can find some of my crazy ideas.
I made this little box for my girlfriend. It contains an USB-stick with our memories.
But you can it only open if you know the secret.
You can guess how it works, but if you want to know it instantly go to step 9 or watch the video.
What you need
  • 1 wooden cube
  • drill
  • pencil
  • tape
  • scroll saw
  • sandpaper
  • a nail
  • pliers
  • water colors
  • spray lacquer
Step 1: Drill a Hole
First drill a hole near the bottom in the middle of the cube.
Don't drill it all the way through.
Step 2: Draw a Heart
I drew a heart on one side and covered it with a piece of tape.
This tape helps to cut the wood on the scroll saw. I don't know why but it works
Step 3: Sawing
First I cut out the heart.
Then I cut the bottom and the lid of the heart
Finally I removed the inner part of the heart.
Step 4: Glue the Cube Together
After sawing the cube has a gap.
I put some wood glue in this gap and clamped it with a little clamp.
Step 5: Glue the Drawer Together
I applied glue on the edges of the inner part of the drawer a put the lid and the bottom on it.
I made this inside the cube to be sure everything fits perfectly. But be careful, don't use to much glue and glue the drawer to the cube!
Step 6: Put Two Nails in the Hole
Cut two identical pieces from a nail.
The length of both must be shorter than the depth of the hole!
They must easily fit in the hole without any friction!
Step 7: Close the Hole
I sharpened a little stick of wood with a pencil sharpener, removed the tip with a knife and glued it into the hole.
After the glue was dry I cut it with a Japanese saw
Step 8: Paint and Finish.
I sanded it with sand paper, painted it with water colors and add some coats of spray lacquer.
Step 9: How It Works
First you have to spin the cube very fast.
Therefor one pin goes to the right and the other goes to the left and than you can put the drawer into the cube. Put some little treasure in the box, close the drawer and tilt the box.
Now you can it only open if you spin it again.
Keep the secret!
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    3 Comments
    personally I would have skipped the paint but I love the box. Maybe someone (my husband or one of my sons) will make me one.
    Clever idea. I like such things.
    This is cool.
    Don't normally comment but felt I had to as water spilt on my phone and it proceeded to keep telling me that I had flagged it as inappropriate. No idea if that actually happened or my phone had a small fit...
    So to the creator my apologies, and to anyone who checks any flags, please ignore and don't shout at me too much...
    Sorry :-)
