loading
Step 4: Assemble Graphic
Since I am printing out the graphics for the sides of the Franzia box on several sheets, I wanted to make sure the image was a crisp as possible. Basically, when I taped the images together to make one large image I didn't want gaps between the pages. I figure out a really good way to do this that involved taping mostly on the back of the images (as opposed to the front where everyone could see it). This worked out really well...people in my office even thought the box of wine costume was a real box printed by the Franzia company which was pretty awesome!
Cut Images: cut off grey edged to cut images out. I used a paper cutter to make this really easy, but you can also use scissors.
Assembly
  • Cut the blank pieces of computer paper in half so you have some strips of plain white paper.
  • For the front of the box there are 6 images that are put together to make the large image with two columns and 3 rows. I taped the two images in each row together and then taped the three rows together. Do the same thing for the back, sides and top.
  • TO TAPE: tape the two images in each row to one of the strips of white paper. Only tape on the backside. I added a few SMALL pieces of tape on the front side to keep everything aligned
  • Use this same technique to attach the rows together
<p>Thanks for the Great Costume Plans. I was able to throw this together in about 45 minutes before a party. Thought I would share a few lessons learned while building it.</p><p>-You are probably not going to be able to reach your own spout. Or a lot of anything else. But it is manageable. I wore a backup costume under the Boxed whine costume so when I took it off for a break I was still in the Halloween spirit.</p><p>- I used spray adhesive to clad the box. </p><p>- I would recommend using packing tape to water proof around the spout. My box ripped around the spout after a couple hours of use. </p><p>- I used one of the packing boxes from U-haul . It was roughly the correct dimensions. I only had to score two new corners to re-fold it how I wanted. Much faster than constructing my own box.</p><p>- a layer of insulation between the wine pack and your body is recommended. Parts get cold after wearing it for a while... </p><p>Again, the costume was awesome. A great hit. Thanks for helping make this Halloween great.</p>
<p>hahahahahahahahahahahahaha! i'd be afraid of how it would look to drink from it if a <strong>guy</strong> were wearing it, though!!</p>
So much fun!!!! Thanks for the help!!
<p>so much fun</p>
I won the costume contest! Such a fun costume. Thanks
<p>Looks great! Were you able to sit down in this costume? I'm making it to wear to work tomorrow so was wondering...</p>
<p>I can't locate the .pdf pictures. Any help appreciated!</p>
<p>The jpeg files are the pictures themselves above.</p>
<p>This is so detailed and amazing! You may want to edit your saying,&quot;YOUR READY TO DRINK!!!&quot; to &quot;YOU'RE READY TO DRINK!!!&quot;. I think this is absolutely the best costume I have viewed this Halloween season. Thanks for sharing your instructable! </p>
<p>I can see the pictures to print but the first two of the front of the box are not the right size!!! everything else matches up fine but those two the Fran zia is to small and smaller then the other pictures please help! </p>
Fundamentally disturbing spout placement. Beyond that ... awesome costume.
<p>Maybe if it were red wine instead of white...</p>
<p>I want a drink :,{</p>
<p>I can't find the .jpg files here. I printed using the files that she has attached. But they seem to be too small. Does anyone have any hints? I don't have .psd. </p>
<p>When I attempt to download the images onto photo shop, only 1 image appears. For example when I click on &quot;Franzia Top&quot; only 1 image shows up on photoshop when I am sure there should be more than one image. The same goes for the front and the side. This might just be my lack of knowledge of the Photoshop program. Could anyone offer any advice?</p>
<p>When you open the photoshop doc make sure you have the layer view open. There are multiple layers per doc. Each layer is a different part of the the squares that make up each image. By turning off and one each individual layer you will get once piece of the picture &quot;puzzel&quot; </p>
Hi there - this is genius and your step by step process is brilliant. However when I open the printables in the .psd I don't have the proper program or something because it's all symbols and broken up. Is there another format you might have this in and be willing to share?
.PSD is a Photoshop document
<p>I can't get the images, I don't suppose you can repost, they are corrupted. </p>
Thanks so much for a great instructable! The costume was a major hit and won a costume contest.
This is so great because it is essentially a &quot;social&quot; costume. You should make sure to have a cameraman friend, cause half the fun is all the funny pictures of your friends taking a drink, and the unexpected funniness of odd|weird|unexpected costume characters doing it.
OMG! You should take someone in this costume with you! <a href="http://www.instructables.com/id/Interactive-Instagram-Costume/" rel="nofollow">http://www.instructables.com/id/Interactive-Instagram-Costume/</a>
Hi, Im trying to print the graphics and the psd is only giving me one picture instead of the 4-6 that are in there?? Am I doing something wrong? I tried from another computer and got nothing but broken symbols and letters when I tried to open it.
tf2 sniper once said &quot;ah piss&quot; jaratate <br>
If you are going to go as a box of white wine for Halloween, you should at least call it something like &quot;Cardbordeaux&quot; ...
Great idea! But there is one thing that would make it a perfect last minute costume. PDFs... They always print at the same size for everyone. It took my neighbor and i about 20 minutes to construct the box and then went to kinkos do print. But we ended up spending an hour trying to get the jpegs to print at the right size using their crappy software. We ended up ditching the idea lest we miss out on the festivities. Otherwise, great instructiable!
It says that you also added the .jpg image if you dont have photoshop and I unfortunately dont have photoshop so I can't print the images. Can someone guide me to where those are? <br>
you can download the files and use online file conversion. i used go2convert.com and converted them to .jpeg
your first photo looks wrong
CONGRATS TO: He11uvaCook for winning the BOX OF WINE CHALLENGE<br /><br />I want to thank everyone who participated! I'm really impressed with how your costumes came out and SUPER flattered that you liked the costume enough to make it! This definitely inspired me to start running more challenges like this on other projects.<br /><br />Because all the entries were so awesome I'm giving everyone a 1 year pro-membership! You will receive a PM letting you know how to redeem your pro-membership. <br /><br />I included some pictures of my friend Alana wearing the box of wine I made on Halloween night. You can see me in some of the pictures (I'm Xena - Instructable coming soon). <br /><br />CHEERS!!<br />Carleyy
Winners!
I made the costume and it came out great! The only tip I have to offer is to drink some of the wine from the bag. 5 liters gets heavy after a few hours.
A box of wine drinking a box of wine. AWESOME!
Double trouble! Made one for me, and one for the wife!<br>Had fun making this AWESOME costume....got lots of complements....<br>I basically used the same files to change the hue for the red color, and just edited the name of the wines ( La Rubia &quot;Blondie&quot;, and Matador Red).<br>Everything worked according to the specs!<br>Cheers!<br>
Didn't think of this as a couples costume, but it definitely works!! I love the picture of you and your wife on the dance floor!
SO much fun with my costume! Very heavy at first though, much better after giving out drinks : )
What did you use to secure the wine bag?
I am not too artistically inclined and had some issues. But i was a huge hit around the neighborhood. I have had requests to wear it every year. I may install a cup holder. Also, i placed the spout on the side to make it more authentic, so as not to make women uncomfortable and because there was already a hole in that side. I heard a lot of &quot;best costume ever&quot; and &quot;hey your leg smells like wine&quot; I may be &quot;Christmas box o9f wine guy&quot; and &quot;Easter box of wine guy&quot; Maybe I will rent me out for weddings. I actually had a few people ask where they can buy a box of wine that size....
I love that you wore this around for the parents - they deserve to have their own 'treats'. I totally understand the need to PG the costume for the ladies. Looks awesome!
It only took me a few hours to make this (with the help of the images already done from this instructable). Everyone loved it! I went as 'Snooki's ultimate accessory - vino'. I &quot;classed&quot; it up by choosing the Franzia Chablis instead...
Fist pumping Box of Wine style!
Me and my brother made it, we had some a few setbacks with our printer but we figured it all out and had to keep in the gray edges on the pictures but it still looked great. Everyone that saw it thought it was hilariously awesome. My brother said when he wore it that everyone was slapping the box before they would take a drink. This picture is after he had been partying in it all night, so it got a little ruffed up.
Looks like you and your brother had a pretty awesome halloween by the looks of the box!
I mentioned this little project at work and they allowed me to print it on our 4-foot plotter in high-res full-color on beautiful paper! I mounted it to foam-core w/ spray adhesive, then taped it to the shoulder-mounts! I cut a hole in the front for the spigot, then hung the box o' wine from my neck w/ a luggage strap! I would advise removing half of the wine from the box to lighten the load on your neck because my neck was killing me the next day! Other than that, the costume was a huge hit! We're now planning a Tour de Franzia Party wherein this costume will be worn while we play Slap the Bag, and drink from a wide selection of the World's Most Popular Wine! <br><br>Note: I recessed the sides of the box so that I could bend my arms at the elbows because the front is just larger than 30 X 30 inches. I couldn't even reach my own spigot, but people didn't hesitate (much) to serve themselves!! What a blast this costume was!! <br>
Thanks for letting us know how you modified the box.<br /><br />I hope to see an instructable on 'How To Throw a Tour de Franzia Party' soon!!
Here are a few more pics that show the construction of this costume a little better! <br>
Thanks to everyone who entered my BOX OF WINE Challenge!! I will review your posts today and announce my decision tomorrow.<br /><br />Cheers!!<br />Carleyy
This costume was awesome. The laughter from people was pretty ridiculous when we dispensed the wine. The wife went as the wine box and i went as a wine sommelier. <br><br>Putting everything together was fairly easy one it was cut out.
Your wife looks so cute in the box! I love it!!
About This Instructable
212,768views
226favorites
License:
Bio: Former Instructables employee CHECK OUT MY WORK www.carleyjacobson.com
More by Carleyy:Makerspace Contest 2015 MakeyMakey Build Night (January 2015) DIY Clocks
Add instructable to:
