Step 4Attach the bracket to the pipe section
You will be inserting the bracket on the inside of the pipe and running the screws from the outside of the pipe to the inside. Manipulating the nuts on the inside of the pipe can be tricky. I used pliers to hold the wing nut in place while I turned the screw to get it threaded.
I used split lock washers on the outside of the pipe, but I am not sure if they will work. Due to the pipe's plastic composition, I wasn't able to tighten down the screws as much as I'd like, since the force warps the pipe and could potentially break or crack the plastic.
Add Comment
