3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Braided Skeleton Knife Handle
Let's use a training Karambit knife.
It is made of 5 mm thick PVC.
This braid can be done in any type of knife flat handle.
No need for drilling or special shape to hold the cords
Step 1Materials Needed
Materials Needed
Paracord 550
Adhesive tape
Curve Hemostat (can be a needle-nose pliers or a strong clamp)
Round tip spatula (or any tool that can drive the string without spoiling the paracord)
Lighter
Knife or other tool that will receive the braided
For sharp knives, I recommend protecting the edge with tape to avoid the accidental injury.
32 comments
Apr 11, 2012. 10:30 AMtriumphman says:
The key question is : how do you know or measure out the length of cord to use? Every knife is different in handle length! I don't want to come up short with the cord. Can you give me a way to measure the handle then measure the cord out so it will be long enough to finish the wrap with some left over for a decorative end lanyard ? There must be a secret answer to this!!! You did not tell us how you measured the cord out! Thanks.
Mar 16, 2012. 7:21 PMBarrettkg says:
I did this a while ago and kept forgetting to thank you for it! The first couple steps took a while to stick but after that I got it goin! It was the perfect compliment to the already rugged look of my knife and I still get comments about it.
Apr 3, 2012. 1:31 PMtriumphman says:
Did you check out my instructables? I have a couple using the Karambit type blades! Thanks again for sharing!
Mar 2, 2012. 2:23 PMhalfway23 says:
Is it possible to do this wrap on a round handle like a flash light? Or does it have to be flat?
Feb 16, 2012. 1:02 PMblack hole says:
Where did you get your PVC? Nice wrap, by the way. I'm always looking for knife handle wraps that don't require holes to be drilled.
Feb 21, 2012. 4:14 PMblack hole says:
Oh, no problem. I might be able to find it in the US.
Jan 8, 2012. 2:01 PMShadow13! says:
Here's a picture of a homemade kerambit that I wrapped using your instructable. The knife isn't quite done but I think it turned out pretty well.
Feb 3, 2012. 11:15 AMcurvy77 says:
beautiful. great knife
Feb 4, 2012. 7:51 PMShadow13! says:
Thanks. It took me many poorer knives before I was able to make that one.
Feb 4, 2012. 7:49 PMShadow13! says:
Thanks.
Feb 3, 2012. 11:18 AMcurvy77 says:
would the edge be on the inside of the blade or outside? and would it be safe to say this is a very lethal tool even if just a practice one?
Jul 29, 2011. 9:12 PMdman07 says:
Great Job, Thank you
Jul 5, 2011. 7:03 PMpaperairplanecreator says:
Uhmm... on the last picture of you wiht the knife facing down, your wrist looks like it has a cut or some type of burn. Anyway, it looked painful.
Jul 11, 2011. 1:18 PMpaperairplanecreator says:
Oh man im so sorry! Didnt know thats what happened, and i didnt mean to bring that up...
Jun 21, 2011. 6:55 PMclax1227 says:
I forgot where do you "insert" the knife for the proper "results"?
Jul 8, 2011. 6:53 PMclax1227 says:
Re-read the question but put this after the question ------> (in combat)
Jun 27, 2011. 5:26 PMtriumphman says:
Good to see someone else knows about martial arts training and using safe practice weapons. The real ones hurt too much. Nice job on that handle, I may put this on my wood karambit knife.
Jun 19, 2011. 7:03 PMtriumphman says:
Will this work on a homemade karambit knife made of 1/4" stainless steel ? I like your knife shape, may I use it to make one of Stainless Steel ?
Jun 21, 2011. 11:42 PMshadow wave rider says:
can you give me some info about how to make one of these knives
Jun 20, 2011. 11:20 PMshadow wave rider says:
where did you get the knife from
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:jgjen
