Braiding eight cords into a flat braid
Everyone can braid things, right? Can you braid more than 3 things? Here is how to braid 8 strands of cord, string, yarn, leather strips or you name it.
Step 1Start with 4 and double down
Take four strands of cord, string, yarn, or these things which are the "self ties" out of old yoga pants.
101 comments
1-40 of 101next »
Nov 27, 2011. 12:38 PMBurnTheVeil says:
Fantastic^_^ I joined this site today after reading this, my crafts involved used guitar string wire, macrame and leather, so I was trolling sites looking for new weaves. This I've seen before but always with 8, my cat decided to steal one of my shoestrings I was practicing with so I did it with 7. Turned out cute! Thanks for posting!
Apr 11, 2011. 5:54 PMbaniaz says:
how long do these strings need to be?
Oct 8, 2010. 1:02 AMabylu says:
Im making a denim 8 strand flat braid bracelet for a gift.. my friend's birthday is this sunday, I think I'll be posting some pictures after I finished it. BTW thanks for the instructable.. it was very easy to follow...
Jun 21, 2010. 8:48 PMajabc94abc says:
How long should the cords be? I'm making a belt. All I have to know if it has to be twice as long as your waist measurement, three times, etc... I'll try it out with extra, but I would appreciate if you would get back to me. Otherwise, I am so excited to try this! It looks great :)
Jun 20, 2010. 8:10 PMmysss says:
I agree; I would like to see more designs for bracelets. I'm really into knot tying and this sort of braiding, and I've never seen/known of this method for finishing a braid/plait. Have you tried this with round cord/string? If so, does it work as well as with the flat stuff used in the instructable? Thanks.
Jun 21, 2010. 6:06 PMmysss says:
The only way I've ever done it is by melting the string (I only ever use synthetic string, for the most part, because for some reason I can never find anything else) so that the ends of everything fuse together. Now, this method kind of sucks, and I presume grows much more impractical if you try it on something larger, such as this project. Or flatter, actually, for that matter. I guess I should elaborate on "sucks." I mean that it's difficult to get it to look good, and it's pretty crude. I'm not sure how well the method someone else suggested (using a hot blade/wire to cut off the ends) works, because I've actually been waiting for an order of new (cheap) knives to arrive before I try it (I don't want to risk my beloved pocketknife this way, and I actually just found out about the method of heating a knife...). It seems to me that this wouldn't work as well for this purpose, even though it finishes the ends of individual cords nicely, since the melting is much more localized than using an actual match/lighter/gas stove flame (lighters work best, I think. I've seen my dad use the stove, and have burned myself with matches doing this [don't judge me]), but this is only a guess. A footnote to both that and my own suggestion is only to use the method on synthetics, not natural fibers which burn instead of melt. Good luck finding a way that satisfies you! (And keep us posted.)
Jun 19, 2010. 9:38 AMladyKrone says:
My husband and I are involved in a "living history" group, and this braid makes a fantastic belt. You can also braid using embroidery thread or thin ribbon to make very interesting looking trim for clothing, too. Great instructable!
Apr 28, 2010. 3:48 PMplatinum15 says:
 LOVE IT!!!!!
Apr 28, 2010. 3:55 PMplatinum15 says:
 wait....im still confuzzled about the braiding part tho :\
Apr 28, 2010. 8:54 PMplatinum15 says:
thnx(:
Oct 26, 2009. 9:33 AMstudent.mckinney says:
Can this be done with more than eight, just continuing the pattern as necessary? i wanna make some visibly woven shoes, and this looks pretty suitable for it if i can get it wide enough.
Feb 15, 2010. 7:41 PMbootspur says:
I am new to this message board and site. I am wondering if you might be able to tell me what the necklace is called by that we men wear that appears to be made from leather, is braided OR woven the proper term I am unsure of, they are very thick and very sexy... Can you tell me what they are called?
Dec 15, 2009. 3:46 PMMusicman41 says:
You can do an odd number.  You do the exact same thing, except you continue weaving until you are just passed the middle strand.
Feb 11, 2010. 6:08 PMalandrak says:
I did this today with some embroidery floss I found. I screwed up about 7 times, but it still looks nice, I think. Thanks for the instructable!
Jan 12, 2010. 12:58 PMstarrymirth says:
Thank you very much, this is awesome.
I have attached pictures of my first two attempts.
The first white one is still in progress, out of 8 strands of string as I was learning how. It doesn't yet have a purpose (and I have no insight for how to end it.)
The second one, which I would not recommend  for those without large amounts of patience (It nearly drove me crazy with frustration and took me several hours) is 16 strands of multi-core wire.
It was initially going to be a cool cable, but later we figured it wouldn't fit into the connectors well, so I made it into a bracelet, by soldering the wires onto another connector and neatening it up with heat shrink.
May I suggest a slight name change to the 7th step? (Step 7: 3rd over 2nd, 2nd over 4th.) I got stuck several times, because I only read the text and didn't pay too much attention to the pictures, I didn't notice that the 2nd strand laid over the 4th.
Otherwise, excellent 'ible!
Sep 5, 2008. 4:34 PMRob K says:
Nice 5/5 I'm going to give this a try. I need a new belt because the old one I have the leather weave is getting stretched out. I will put up a picture if I get it done.
Sep 6, 2008. 7:36 PMRob K says:
I did not use leather or a belt buckle. This was nylon 1/8" utility line that was gray and white. The buckle itself is two 1.5 Inch steel rings.
4 strands a 12 feet I just went twice my height per strand.
I don't have a way to measure the belt so I will just use the nose to tip of fingers method . Belt goes from tip of fingers to nose then back along the belt to the elbow. Guessing around 42-48 Inches long.
Any way to add more stars for having good directions?
Sep 7, 2008. 6:15 PMRob K says:
LOL. I just was saying that your directions where easy to follow.
Dec 17, 2009. 7:54 PMRob K says:
I still use mine. It still works great.
Dec 10, 2009. 9:37 AMLondonbrig0 says:
This is really cool, I can't wait to make my own!
Apr 3, 2009. 9:45 AMNotOurKing says:
I've always thought of this type of braiding as simple weaving and multi-strand braiding as a more complex pattern. I found an Instructable for it here http://www.instructables.com/id/How_to_weave_an_8_strand_braid_on_a_wooden_loom/
For anyone making hemp bracelets I recommend macrame, it's what I used to use and it was very popular. Once you get good at it, and learn a lot of knots, you can make some really pretty patterns.
Sep 11, 2009. 10:22 PMNotOurKing says:
Ah, thank you. Now that I think of it, that makes more sense. I was thinking that the basic flat over under pattern was weaving, but I wasn't considering all the beautiful woven rugs that don't follow that pattern.
Aug 28, 2009. 6:25 PMsmithy813 says:
very nice, once you get the pattern down theirs no limit to what you can do with it :) I made some out of #42 seine twine to replace the non existent handles on a chest I have. I just use constrictor knots to end all my braids and seinets, btw.
Aug 12, 2009. 2:07 PMJimichan says:
I made a belt out of paracord using this weave to take mountaineering this summer. I used a plastic buckle I salvaged from an old waist pack that allowed me to make the length adjustable. To finish the end of the belt, I ran it through a small D carabiner, wove it back into the belt and tucked the ends up into the hollow part between the 2 layers. (Not a very good description, I know. I was just winging it, though. I'm sure you can figure it out.) The carabiner allowed me to fasten the loose end to the belt, and made a handy place to hang things. Now that I'm back, I'm sure I will revise the design and post it here. Thanks for the inspiration!
1-40 of 101next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:hammer9876
