3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Braiding eight cords into a flat braid
Step 16Just end it all
Just end it all
To end it, tack down the ends either straight across or in a "V" shape. Third image is machine sewn in the "V" shape. Select a thread color to either match or contrast your braided colors and using a tight zigzag stitch, machine sew following your previous stitches. Trim the ends. Done.
16 comments
Jun 20, 2010. 8:10 PMmysss says:
I agree; I would like to see more designs for bracelets. I'm really into knot tying and this sort of braiding, and I've never seen/known of this method for finishing a braid/plait. Have you tried this with round cord/string? If so, does it work as well as with the flat stuff used in the instructable? Thanks.
Jun 21, 2010. 6:06 PMmysss says:
The only way I've ever done it is by melting the string (I only ever use synthetic string, for the most part, because for some reason I can never find anything else) so that the ends of everything fuse together. Now, this method kind of sucks, and I presume grows much more impractical if you try it on something larger, such as this project. Or flatter, actually, for that matter. I guess I should elaborate on "sucks." I mean that it's difficult to get it to look good, and it's pretty crude. I'm not sure how well the method someone else suggested (using a hot blade/wire to cut off the ends) works, because I've actually been waiting for an order of new (cheap) knives to arrive before I try it (I don't want to risk my beloved pocketknife this way, and I actually just found out about the method of heating a knife...). It seems to me that this wouldn't work as well for this purpose, even though it finishes the ends of individual cords nicely, since the melting is much more localized than using an actual match/lighter/gas stove flame (lighters work best, I think. I've seen my dad use the stove, and have burned myself with matches doing this [don't judge me]), but this is only a guess. A footnote to both that and my own suggestion is only to use the method on synthetics, not natural fibers which burn instead of melt. Good luck finding a way that satisfies you! (And keep us posted.)
Jun 19, 2010. 9:38 AMladyKrone says:
My husband and I are involved in a "living history" group, and this braid makes a fantastic belt. You can also braid using embroidery thread or thin ribbon to make very interesting looking trim for clothing, too. Great instructable!
Oct 26, 2009. 9:33 AMstudent.mckinney says:
Can this be done with more than eight, just continuing the pattern as necessary? i wanna make some visibly woven shoes, and this looks pretty suitable for it if i can get it wide enough.
Feb 15, 2010. 7:41 PMbootspur says:
I am new to this message board and site. I am wondering if you might be able to tell me what the necklace is called by that we men wear that appears to be made from leather, is braided OR woven the proper term I am unsure of, they are very thick and very sexy... Can you tell me what they are called?
Dec 15, 2009. 3:46 PMMusicman41 says:
You can do an odd number.  You do the exact same thing, except you continue weaving until you are just passed the middle strand.
Dec 10, 2009. 9:37 AMLondonbrig0 says:
This is really cool, I can't wait to make my own!
May 14, 2009. 3:32 PMwordgirrl says:
i've been looking for a way to make a strap for a camelbak unbottle to wear slung over my shoulders. i'm a knitter, so i'm likely to use some cotton yarn, if i can figure out how to finish the ends sturdily. this is a really great instructable!
Jul 7, 2009. 8:34 AMNick11255 says:
If you use nylon strands you could use a heated knife to cut it off at the end and seal it. Could i use leather?
Aug 4, 2009. 3:19 PMLinneaDrue says:
I have actually seen something like that done with leather a few times at a European archaeology event. For the ends they simply cut circles out of the same leather, folded them in half and sewed them on both ends, which is pretty sturdy and also convenient if you want to attach something to the ends.
Jul 4, 2009. 9:08 AMjeanhhl says:
I made my own belt using your tutorial. It's so easy. I used just 30min while I was watching TV.U can use rope also. Thank you for your tutorial.
Mar 28, 2009. 7:56 AMDIS.AR.RAY says:
that looks amazing! I've been selling hemp bracelets at my school, but I always wanted to do cooler than just the normal hemp designs. I'll give this a try, a long with some leather cord. :D Mucho Gracias
Apr 1, 2009. 2:47 PMmg0930mg says:
DIS.AR.RAY should make one about it...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
36
Author:hammer9876
