Branding Nails
32,261
337
34
Published
Introduction: Branding Nails
About: I make and create anything that comes to my mind from skateboard hooks to garden rooms. And I footle around with electronics and instruments at night....and I have a passion for reducing waste packaging by m...
A great little project to make some tiny branding irons out of wire nails...
Step 1: Get Your Bits Together
MATERIALS
Wire nails - I used 125mm wire nails that have a head of about 10mm diameter
Block of wood - for the handle
Sticky backed vinyl sheet
Propane gas
TOOLS
Etching tool - you will need to make your own, easy to do
Salt water solution
Hammer
File
Sharp knife
Rotary tool + grinding wheel
Step 2: Hammer
Hammer the nail into the end of a block of wood...
...this will make it easy to hold the nail to work on the end
Step 3: File
File the nail head flat ready for etching
Step 4: Stencil
Cut out your design from a sheet of sticky backed vinyl...it will be tiny!
Remember to reverse the design especially for text and logos...as with all printing it has to be reversed so it will be the correct way when burnt into the wood
Firmly stick the stencil to the nail head
Step 5: Etch
You will need to make an etching tool...check out my Metal Etching video or have a look at Laserage's Instructable on how to etch with a battery.
Attach the etching tool
Plug in the transformer
Pour out some salt water solution...
...and dip the cotton wall on the end of the etching nail into the solution.
Press the tool onto the end of the nail head and hear it sizzle...etching is taking place.
Fumes are produced...PLEASE make sure you undertake this in a SAFE well ventilated place and do not breath in the fumes.
Step 6: Clean Up
It will take around ten minutes to produce a good deep etch and a nicely defined edge to your stencil.
A crud will have formed on the end...scrape away with a knife to reveal your design
Step 7: Grind
Cut away the excess metal around your design...
...this is too enable the brand to be as clean as possible without metal to the side scorching around the brand.
Take it slowly with a steady hand so the etched edge isn't nicked by the grinding wheel.
A rotary tool and small grinding/cut off wheel works really well...a hand file should do the job as well.
Step 8: Handle
Cut the wooden block to a convenient length as a handle...
...plane...cut...sand to a nice finish that feels good in your hand.
Step 9: Burn
All ready to brand some timber...
Heat the end of the branding nail with a propane torch.
It will take a little practice to work out how hot you will need it...grab a scrap piece of wood and do some practice runs.
Place on the timber for a couple seconds...
...pull away...
...NICE!
Step 10: Brand Your Branding Nail!
Why not brand your own branding nail!
It makes sense so that you can easily see the design of the tool...especially that you will want to make lots of them.
Remove the nail from the wood...
Heat up the nail head as before...watch those fingers as you do not now have a nice timber handle to insulate from the heat!
Brand the handle...
...Carefully tap the nail back into the handle.
Step 11: Looking Good!
Step 12: ENJOY!
These are super useful and so small...perfect for branding little things!
I am entering this project into the Pocket Sized Contest as they are pocket sized! and if you have enjoyed this project, I would really appreciate your vote...thank you so much.
This project is part of my YouTube channel where I try to make cool and interesting projects.
Please check out my channel if you want to see more of the projects, if not there will be more coming to Instructables soon.
Why not check out what I am up to on Facebook.
Pocket-Sized Contest
Runner Up in the
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    34 Comments
    Very nice tutorial !! And congrats for the win! :)
    Thank you all so much for voting me into the finals...super happy
    fantastic! I am now set for some gifts for some of my Texan neighbors and family. Wow.
    Thank you very much.
    _ga-
    Very neat! How do you keep from burning in too deep, causing a circle from the nail head?
    Grind away as much as possible for the outside of the shape will help, then practice on scrap piece of wood to work out best heat to the mail head and length of time held on timber for the brand.
    Due to the tiny size of the branding iron there is a tendency of scorching though excellent results are easily achieved.
    Give it a go!
    Intricate logos are possible, I made one of my logo, just had to make sure it had a really deep etch to make the edges clean. Then some practice in hearing and length of time e branding to get a good brand. Thanks for your kind words.
    I never would have thought to use a nail head for a branding iron, but it's perfect for small logos! Great instructable, thanks for sharing.
    Thanks Makerneer...they are great for branding little things or a discreet mark on larger projects.
    Cool...let me know how you get on.
    Great idea.
    IMHO it can be combined with a laser toner transfer (that used for homemade PCB's) - that may be good to make something complicate. Like a logo. Of course, fine elements will be "smoothed" during the etching, but it may bring some improvement.
    Good idea, i am sure that would work...i haven't ever tried it, I must look it up. Thanks
    Ohhh maaaannnnn!!! this is one of the coolest and most innovative ideas i have seen. i wondered how you would cut the patterns into the nail head. etching it did not come to mind. thanks for sharing.
    I love this idea, thanks for posting!
    I'm experimenting with making batik stamps, maybe I could try to use this technique for this purpose as well, so you've inspired me with this project.
    I alsolike pyrography by the way, so I could use these in a woodburning project as well.
    Great, let me know how you get on
