3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bratz Knife Block
Step 4Prep and cut the block
  • last photo ←
Cut the block of wood so that it is roughly the same size as the strumpet doll. Sand it down if needed.
Lay the lifeless naked body against your (block of) wood. Decide where you want to impale her with specific knives, and make corresponding marks on the wood with a fine point sharpie. For the type of stand design that I will use, it will be best to position the longest knife at the top of the block and the shortest at the bottom (Actually, I am pretty sure that holds true for all knife block designs). I decided to have one knife going through her fat head, one through her torso, one cutting off her arm, and one slicing open her leg.
The next step is to cut out the slots, any suggestions on how we do this strumpet doll?
::chuckles:: so true, so true...
Seriously though, finding a way to cut out these slots was one of the most time consuming parts of this entire project. I went at them with a drill, a jig saw, a sawz all, a hammer, a screwdriver, and a dremel, and was only able to make small progress. In the end a milling machine was used, and the slots came out pretty nicely. If you do not have access to a milling machine, your best bet is to drill a series of holes as close together as possible down the length of the slot, and then use a hammer and sharp chisel to knock out the spaces in between.
Once the slots are knocked out, drill two holes at the bottom of the board for the bolts to go through. Bolt placement does not need to be perfect. The holes just need to be at the proper height to prevent the longest knife from hitting anything behind the block while still allowing for a nice sturdy feel (angle the bock too low and the longest knife will hit the table, angle it too high and the block is liable to fall over). There is some wiggle room in this step, because after the holes are drilled, the bolts can be screwed further in / out to adjust the angle at which the block rests.
5 comments
Jun 11, 2010. 8:38 AMTheInventor1997 says:
why is this in the survival section anyway! GOD! i bet you ****k your mothers a********* what? why'd i get bleeped, i just said drink your mother's applejuice (sorry, i just love smosh! you should check the ask charlie episodes, that's where i got it =P)
Apr 16, 2008. 9:02 AMMisterMissanthrope says:
haha, arent those quotes from what lisas talking malibu stacey doll?
Aug 21, 2008. 8:37 PMBright Shadow says:
lol. I thought I recognized the 'baking cookies' one
May 15, 2008. 9:54 PMstkelsiej says:
yeah... you're just a 'regular weirdo' not one of those crazy ones. These would make great Christmas presents. Maybe a nice Mother's Day gift?
Apr 16, 2008. 5:16 PMMisterMissanthrope says:
yea, i like doing suff with friends and asking "you catch that refrence? how bout that one?" makes me feel like im worth something, im the guy who asks anoying questions whom people only hang out with to make them selves look better, HIGH FIVE!
Apr 7, 2008. 8:52 PMuser669 says:
Nice Tablesaw!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
331
Author:Tetranitrate
I'm attending NYU-Poly.
