Introduction: Braun SyncroPro 7765 - Battery Replacement
If you have a soldering iron, then replacing the batteries in your razor is cheap and easy and you can keep it out of landfill a little longer.
Note: The product design is such that the entire PCB / battery assembly is a replaceable part, not just the batteries, so this is a hack, not a manufacturer designed battery change.
You will need to have  two new 2100mAh (or better) NiMH (Nickel metal hydride) batteries, a soldering iron, small flat head or trox screw driver and cutters.
1. Start by removing the little cover around the charging socket using a thin blade screw driver.
2. Un-clip the side grips, pulling outward from the bottom end. (The grip, hook over at the razor head side).
3. Remove the 4 housing fixing screws, using either a small flat head or trox screw driver.
4. Separate the 2 body halves, pulling them apart from the bottom edges. (They hook over at the razor head side). Work close to a tabletop, being careful that the internals do not fall out.
Step 1: Remove Circuit Board
Open the housing and inspect how items fit together. Then remove the circuit board.
Take note of the terminal directions of the batteries, as you should replace them in the same direction.
Note: The batteries in this razor have already been changed and therefore they are showing the new batteries already soldered in place.
Step 2:
Cut the metal tab terminals off the existing batteries (4 places), making sure that you leave as much terminal on the circuit board as possible, as you will have to solder the new batteries back to it.
I used a Dremel rotary cutting tool, but a file or hacksaw blade can be used.
Remove batteries and discard them responsibly.
Replace with 2 new NiMH rechargeable batteries, by soldering them back in the same terminal direction as the originals.
The close up images show my dodgy soldering of the tabs back the batteries. The terminals on the head side are easy to work with, but the terminals on the socket side are trickier (as there is very little space to work in).
Step 3: Re-assemble Housing.
Re-assemble the housing by doing the reverse steps.
Tip:
Be aware that if you have too much solder on the batteries, then the motor terminals will make contact with the batteries and will run without the switch being in the ON position.
Good luck and keep those good, easy to fix appliances out of landfill!
