Bread Board from IDE Cables
Today we are going to be building a bread borad for protyping circuits. Most of the parts you have lying around. The idea here is not to replace large store bought bread boards but, to construct small units that could be part of a larger project.
Step 1Gather Your Components
You will need
-IDE cable
-small amount of copper wire
-soldering iron and solder
-small piece of plastic
-small screwdriver to take apart the IDE Cable
63 comments
1-40 of 63next »
Jun 24, 2011. 6:01 AMbatman96 says:
Female parallel ports work good too. ;)
Mar 15, 2010. 3:25 PMlaxap says:
Great idea, smart and useful!
I'm making some ASAP!
Mar 15, 2010. 2:50 PMambrosiusamadeus says:
Awesome! One of the better, practical projects I have seen on here in a long time. Well Done!
May 13, 2009. 9:14 AMDoom2099 says:
very cool project. breadboards are expensive. you helped a lot people today! keep it up!
Sep 11, 2009. 1:58 PMzoltzerino says:
I got a 896 hole Board for 5 GBP From Rapid.
Jul 22, 2009. 12:39 AMiamsinned06 says:
i want to make a homemade ide to usb cable. can you give me schematic or diagram or how to do it yourself?
Aug 23, 2009. 12:42 PMcotton says:
u need qa whole circut so goto a computer store and get a ide to usd adapter there round 20 buks to 60 bucks k
Aug 9, 2009. 1:51 PMrommel543 says:
Ah crap.. I just moved and threw out about 10 old IDE cables because (insert wonky music here) I thought I wouldn't use them for anything. Time to start savaging parts at work again.
Jan 24, 2008. 3:14 PM!Andrew_Modder! says:
oh. ok lol a good use for your ide cables, haha. .....damn the ide!! oh ya they actually make SATA dvd and cd writers now!! so you can go 100% ide free!!! woot.. lol nice instructable
Mar 6, 2009. 11:47 AMDerin says:
Invalid.
Correction:
haha. .....damn the sata!! oh ya they actually make IDE dvd and cd writers now!! so you can go 100% sata free!!!
Jun 19, 2009. 10:14 AMtinkerC says:
I like SATA. The SATA Hard Drives have more room than an IDE one. CDs and DVDs can't keep up with SATA speeds, but SATA is easier to wire.
Jun 19, 2009. 10:25 AMDerin says:
OK,I agree now after having to hook up an IDE HD to my PC.The drawback of IDE is Master/Slave.
Jun 19, 2009. 12:14 PMtinkerC says:
Meaning that there is one drive selected to boot from and you need to move the jumpers to change it? That is a flaw in the OS to need that.
Jun 19, 2009. 10:33 PMDerin says:
No,if you put it on the wrong jumper it won't work.And it is a pain to put them on Cable Select.
Jun 21, 2009. 2:32 PMtinkerC says:
Ouch. There must be a better way....
Jun 19, 2009. 9:10 AMjuggler4real says:
WHERE CAN I GET IDE CABLES
May 17, 2009. 10:49 PMDavetech says:
I thought this might be even better than sliced bread, so I put 4 IDE connectors together and soldered them up. I was happy with the result in general, but a bit miffed when I plugged in an IC. It seems that the springy contacts in the connector are just a little too deep for an IC's leads to be securely held and the IC would pop back out when I let go of it. The same happened when I tried an IC socket. Otherwise, it works great for long-leaded discrete components. So I'll just use it as an "add-on" breadboard. ps: I guess you could solder on lead extentions to an IC socket and keep that socket handy to use with the breadboard.
Apr 9, 2009. 1:32 PMjohnfromnj says:
Good idea for all the homebrewer's out there. Those breadboards from Radio Shack are expensive, with a little modding, you could customize them for just about any project.
Feb 19, 2009. 7:42 AMSeifpic says:
Nice idea, I would of never thought of that..
Jan 9, 2009. 10:43 PMcabie62 says:
Why not use SCSI connectors ? and use the cable too. You could use a 2" piece of SCSI cable stack 8 connectors, one right next to the other and have a total of 16 X 50 pins in 16 pin rows.
Dec 19, 2008. 9:22 PMJimwright says:
I will never throw away a (whole) 9V battery again! Why didn't I think of that?
Dec 9, 2008. 1:41 AMLEEKA_IDHAM says:
Great idea bro. Now the rest of us can start from here and build our own boards at a larger scale since most of us seem to have tons of junk IDE cables. I also suggest using a colored (maybe yellow) thin-tipped marker pen to mark the bridged groups pins from the top of the IDE jack. this way it would be easier to distinguish the bridges from top when electronics start to obscure most of the surface.
Jun 8, 2008. 3:30 PMkraM says:
damn i just threw alot of these away when i moved... now i need to find some more so i can make me a bread board, and here i was thinking about buying one soon
Dec 8, 2008. 11:41 PMagis68 says:
i can supply you with a cardboards of them if you want! By the way nice project and smart cause breadboards cost a lot
Jul 1, 2008. 7:32 AMcowtipper97 says:
Me too!! i'm really mad that i did that now that i know a good use for them!
Dec 4, 2008. 7:54 AMprofpat says:
Very good idea, now i can recycle lots of ide cable off my junk bins!! more power and imaginations to Instructables!!!
Nov 10, 2008. 11:03 PMemergencydpt.com says:
Great project. Points for simplicity and repurposing something getting thrown away. You go dude!
Jan 27, 2008. 5:29 PMYerboogieman says:
i absolutely loved this idea but its just so hard to keep the solder on the pins after it dries, it'll chip or fall off
Jul 15, 2008. 10:05 PMstncilr says:
make sure that when you finish your solder that it is atually cone correctly and not ust a cold solder, because cold solders are known to chip off and such
Jun 28, 2008. 9:01 PMgodanimal says:
what is a bread board and what does it do ??
Jul 1, 2008. 5:14 AMtinbin says:
Love it! I need some breadboard to try a project tonight, but don't have time to get to Maplins... gonna try this one, thanks dude! Will it take an IC?
May 23, 2008. 10:26 AMlearningmaster says:
good gob now ill do this right now with my 11 cables *fav*
Jan 24, 2008. 3:09 PMBongmaster says:
nice : i used a plug for a power rail on my breadboard :) might do this for a small breadboard or make more power rails :D
May 12, 2008. 2:47 PMJCru says:
This is an awesome instructible. And to think I was going to buy a breadboard for small projects...This works so better! Thanks!
May 6, 2008. 8:13 AMthepsymaster says:
Wow! Why have I never thought of this before?? Such a simple but effective idea, well done :)
May 6, 2008. 7:46 AMAncientWizard says:
Very resourceful, and nice example of recycling... One thought: you could use a sharpie to mark the connection patterns on the front to show you where your bridged connections go.
May 6, 2008. 7:22 AMgb78 says:
Hey, awesome! Gave me a great clue on what to do with my old bunch of ide cables. Nice job!
Apr 11, 2008. 6:02 AMratgod says:
Great instructable, I used to do this about 10 years a go when I was a poor student type person, but back then I couldn't even afford the luxury of epoxy resin :) I just held 2 connectors together and used the iron to melt parts of the plastic together, was a very lousy and smelly job. I also found that tinning wires before putting them in is good for this as some wires are too thin for the holes and don't sit properly. I may start making more now you have reminded me. thanks
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
37
Author:stone3408
