Breadboard Friendly Tactile Switches
6,965
105
31
Posted
Introduction: Breadboard Friendly Tactile Switches
As most of you have experienced, the good old standard tactile switch is really difficult to mount on a breadboard. This is because the pins are so thin. Even with the pins straightened, they sometimes do not make contact, or just keeps on bending trying to insert then onto the breadboard.
Step 1: Parts Needed
You will need the following spares:
Tactile switches
Piece of vero board/proto board
Pin headers
2 female headers
Step 2: Making the Base
Cut a small piece of vero board into a 5x4 matrix as shown.
Step 3: Add the Tactile Switch to the Base
Insert the tactile switch onto the base.
I like to bend over the pins to ensure the switch is flush with the board.
Solder the switch to the base.
Step 4: Soldering the Header Pins
Cut two pieces of pins, so that each piece have 2 pins.
Using long nose pliers, push the pins flush with the plastic.
Insert the pins into the base.
Use the female headers to keep the pins aligned during soldering.
I used Prestik to hold the assembly during soldering.
Solder the header pins to the base.
The final step is to solder a bridge across the pins and switch connections.
Step 5: Using Your Switches
Simply connect one side of to the switch to the common rails (red or black) of your breadboard. Now only one wire is needed to connect your tactile switch to your circuit.
I hope this was helpfull.
Enjoy.
4 People Made This Project!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
21 Comments
It reminds me of some circuits that we made at ITT Tech nicknamed surf boards these where simple circuits like voltage regulator, a small amplifier, a basic counter circuit with a 555 timer, and others all of the 'surf board circuts ' plug in to a prototype board for all external connections. We got the idea from an electronic magazine article (I forget the name) I think it's popular electronics. We made them for circuts that we found useful and made these for convenience
yes, indeed very nice - I have all sorts of breadboard friendly "things" (like simple switches, leds, pots etc) but it never occurred to me to make one for a tacticle switch .... great work!
Simple and brilliant! Thank you!
Why didn't I think of this? Great idea.
i think its a good idea , i will build it with a build in pull down resistor
A very good idea indeed !
