It is is a simple set of template files drawn to scale with real world electronic components.
Using a vector drawing program you simply move the components onto the breadboard template, draw a few wires and print the result (if you're old school you can print the template and use scissors and glue).
Pin the template to your breadboard, place the components and wires, and you're good to go. Better yet if a wire later falls out its easy to pop it back into place.
Looking to skip ahead?
The Component Library can be found here
The Circuit Library can be found here
(shameless plug)
Like the breadboard layout sheet idea and looking to play around with an Arduino? we make a fun kit that combines the two. (in the UK it can be purchased here anywhere else in the world it can be purchased here)
(second shameless plug)
In the UK and looking for an online shop that sells delightfully fun open source products feel free to check out our web store here .:oomlout.co.uk web store:.
Remove these ads by
Signing UpStep 1Software
Option 1 - Inkscape (modern)
Inkscape is an Open Source vector drawing program. Its a little rough around the edges at the moment but it is only getting better, and when looked at in its entirety pretty impressive.
- Download Inkscape from inkscape.org
- Install
- Download the component library in Inkscape (.svg) format on the next step
- Copy and paste components and move them around (use the arrow keys the nudge is set to 0.1" so you're components will all stay alligned)
Along with the Inkscape format all the files in this instructable are also available as .pdf. What this means is you can download the PDF print it out and then use old fashioned glue, scissors and pen to make your templates. Or you can also download pre-drawn circuits from step 3.
James
PS. they wouldnt last 5 minutes let alone 5 years without the madly complicated wear-levelling algorithms implemented on them, wheres a normal HDD... NOTHING this is what hacks me off... they had to try SO HARD to get them just working for 5 yrs
And then theres the scary thought of servers running on them!?!?!?!
Eesh...
(IMHO)
