3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Solderless Breadboard Layout Sheets (plug and play electronics)
Step 2Component LIbrary
Component LIbrary
To use the components simply download either the Inkscape (.svg) or Adobe (.pdf) file attached to this step.
The current set of components is a bit of a random selection of those we've found useful around the .:oomlout:. offices. More will be added as we draw them.
If you've drawn a component for we'd love to have you share it here (send us a message if you'd like collaboration privelages, or simply e-mail us the file and we'll integrate it into the library)
Current Component List
Breadboards
Breadboards occasionally vary in how they align their power strips, we currently have two supported layouts
Discreet Components
  • Resistors - 1/4 watt resistors currently in (560, 2.2K ohm and 10k ohm) (these are available from any electronics shop, even radio shack).
  • Diode - A simple axial diode (we use an 1n4001 for most purposes)
  • Axial Capacitor - Common form factor for medium sized capacitors
  • Crystal - Metal can type crystal
  • Piezo Element -
LEDs (Light Emitting Diodes)
  • 5mm LED (T1 3/4) - The most common size LED
  • 12mm LED - A large LED
  • Piranha LED - A common form factor for RGB LEDs
  • 8 x 8 Bi-Color LED Matrix - A medium sized LED matrix
Inputs
  • Photo Resistor - A light dependant resistor
  • Pushbutton - Standard sized pushbutton
  • Trimmer Potentiometer - Small potentiometer
  • Panel Mount Potentiometer - Common Potentiometer
Transistors and ICs (Integrated Circuits)
  • 74HC595 - 8 Bit Shift Register
  • ULN2803A - Octal Transistor Array
  • L293 - Quad half bridge driver (can also be used as a dual H-bridge)
  • ATMega168 - An Atmel micro-controller (pin compatible with the ATMega 328 used in the Arduino Duemilanove board)
  • MAX7219 - 8 x 8 LED Matrix Driver (can also be used to drive 8 seven segment digits)
  • LM35 - Precision temperature sensors
  • TMP36 - Precision temperature sensors
  • 2N2222 - NPN Transistor
  • P2N2222A - NPN Transistor
Larger Items
  • DC Motor - A toy dc motor
  • Mini Servo - A hobby servo motor
  • DPDT Relays - A double pole double throw relay
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
407
Author:oomlout
