Step 3Circuit Library
Here are a few we have used around our offices. (appologies at the moment they are solely Arduino based but we are working on a set to explore more general electronics principles)
(If you draw a circuit we'd love if you'd share it here (send us a message if you'd like collaborator privellages or e-mail us the file info@oomlout.com)
(each circuit is attached to the bottom of this step in PDF and .svg format)
Arduino Based Circuits
- CIRC-01 - A blinking LED
- CIRC-02 - Multiple LEDs (connect 8 LEDs to your Arduino)
- CIRC-03 - Using a transistor to drive a small motor
- CIRC-04 - Attaching a hobby servo to an Arduino
- CIRC-05 - Using a 74HC595 Shift register to drive 8 LEDs
- CIRC-06 - Using a piezo element music to make music
- CIRC-07 - Using pushbuttons
- CIRC-08 - Using a potentiometer
- CIRC-09 - Photo Resistors
- CIRC-10 - Temperature sensing using a TMP36
- CIRC-11 - Using a relay
- CIRC-12 - Using a MAX7219 to drive a 8x8 LED matrix
- CIRC-13 - Using a MAX7219 to drive a bicolor 8x8 LED matrix
- BBAC-SHEET - A breadboard based Arduino
CIRC01-sheet.pdf(612x792) 23 KB
CIRC09-sheet.pdf(612x792) 24 KB
CIRC10-sheet.pdf(612x792) 23 KB
CIRC11-sheet.pdf(612x792) 28 KB
CIRC13-sheet.pdf(612x792) 54 KB
CIRC12-sheet.pdf(612x792) 47 KB
BBAC-Sheet.pdf(596x842) 56 KB
CIRC03-sheet.pdf(612x792) 24 KB
CIRC02-sheet.pdf(612x792) 27 KB
CIRC04-sheet.pdf(612x792) 24 KB
CIRC05-sheet.pdf(612x792) 29 KB
CIRC06-sheet.pdf(612x792) 22 KB
CIRC07-sheet.pdf(612x792) 25 KB
CIRC08-sheet.pdf(612x792) 26 KB| « Previous Step | Download PDFView All Steps | Next Step » |
Add Comment
