Breadboard Power Supply With a Slide Switch for Selecting Voltage
3,752
26
30
Posted
Introduction: Breadboard Power Supply With a Slide Switch for Selecting Voltage
Breadboard Power Supply is an option for being connected directly with your breadboard.  This power supply provides 5V & 9V that are selected with a slide switch and indicated them by a green and a red LED respectively.
http://www.youtube.com/watch?v=Pdt1-hNZVrY
Step 1: List of Materials
1      7805
1      7809
1      DC Power Jack
1      PCB
2      Electrolytic capacitor of .1microF
1      Capacitor of 1 microF
1      Slide switch
2      Resistor of 1k
1      Red LED of 5mm
1      Green LED of 5mm
1      40-Header male pin
Step 2: Identify the DC Power Jack
This component is important that be identified in its ends because it only has two polarities (+ & -).  In this case, two ends are negatives.  For this project, you need to use an unregulated wall adapter/transformer 9V, 600mA of positive center so that it can function correctly.
Step 3: Identify the LEDs
Itis important to understand that the LED has that characteristic in its terminals one shorter that other so that you can identify its cathode or negative terminal.
Step 4: Identify the Voltage Regulator
identify the voltage regulators 7805 and 7809.  Observe the photo attached in this step.
Step 5: Identify the Slide Switch
Observe the photo attached in this step, and take your switch and put it on the table as you can see it on the diagram.
Step 6: Observe the Diagram
Observe the diagram and check the components jointly.
Step 7: Install the DC Power Jack
Mount the DC power jack and solder it on your PCB by remmembering that two terminals are negative and one positive.
Step 8: Mount the Voltage Regulators
Install and solder the voltage regulators according to the instructions of connection.
Step 9: Install the Capacitor of .1microF
This capacitor should be connected in the input of voltage of both regulators.
Step 10: Install the Electrolytic Capacitors
Install and solder the electrolytic capacitors by checking the polarities of your capacitors so that you do the connections taccording to the project's diagram.
Step 11: Mount the 5V LED Indicator
Cut two pins of your 40-header male pin so that you can solder them on the PCB to obtain the output of 5V.  You will also have to solder the green LED and the resistor of 1K.
Step 12: Install 9V LED Indicator
Cut other two pins so that you can obtain the connections to the output of 9V of your power supply.  You will also connect the red LED and the other resistor of 1K.
Step 13: Install the Slide Switch
Mount the slide switch and connect it according to the project's diagram.
Step 14: Complete Your Project
For completing your project, probe it by plugging into the AC power through your unregulated wall adapter/transformer of 9V, 600mA.
Step 15: Check the Voltages
Check the voltages of 5V and 9V with your multimeter.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    30 Comments
    This project can also be seen in Jameco Electronics at:
    http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=2192114&catalogId=10001&CID=CLO
    LEATHERWORKING classes are now free in this site.
    PHOTOGRAPHY classes are now free in this site.
    CANNING PRESERVING classes are now free in this site.
    BREAD classes are now free in this site.
    WOODWORKING classes are now free in this site.
    GLUE classes are now free in this site.
    CONCRETE classes are now free in this site.
    MEAT classes are now free in this site.
    WEARABLE PI classes are now free in this site.
