Breadboard to Perfboard
Published
Introduction: Breadboard to Perfboard
About: DIY, Arduino, make, solder
Sometimes it is easier to get your electronic project working on a breadboard before you start soldering things together. In this tutorial, we will explain how to take your project from the breadboard to a protoboard or perfboard.
First make sure you have all the same parts. For example, if your project has 2 capacitors, you need 2 more capacitors for a total of 4 capacitors. 2 capacitors for the breadboard and 2 for the perfboard version.
Once you have your project working on the breadboard, leave it alone. This way you can refer to it when soldering the perfboard. This process is the same not matter how simple or complex your project is.
In our example we will make a simple led circuit with a switch and a battery.
You will need a soldering iron like the Weller WLC100 40W Soldering Station if you don't already have one.
You may already have some of the parts but here is our parts list.
2 4 cell AA battery holder - Tayda Electronics 4 x AA Battery Holder
8 AA batteries - 8 pack Duracell AA
2 5mm leds - 5mm Yellow Leds Tayda Electronics
4 short wires - The Soldering Station Black 22 AWG Wire
2 1k resistors - Tayda 1K OHM 1/4W 5% Carbon Film Resistor
2 slide switches - Tayda Electronics
1 half breadboard - Tayda Electronics
1 small perfboard - The Soldering Station Small Perfboard
Step 1: Wiring Up the Switch
To begin we will need to solder 2 wires to each of the switches. Turn on your soldering iron and let it heat up.
Start by bending a small hook in one of the black wires and hooking onto the switch at either end and the soldering it.
Then solder the the red wire in the middle. Make sure that neither wire nor the solder is touching each other. Now solder together the second switch the same way. The wire color for the switches does not really matter here. If all you have is one color of wire, that is fine.
Step 2: Setting Up the Breadboard
Now let's put the bread board together.
The red and blue areas are connected horizontally while the inside columns are connected vertically. Connect the red wire from the switch to the red line on the bread board and the black wire to a row in the middle of the board. Now connect the led short lead onto the black line and the short side to the middle of the board.
Then add the 1k resistor connecting one end the the led column and the other end to the column that the black wire from the switch is in.
Now connect the black wire from the battery pack to the blue line on the breadboard and the red wire from the battery pack to the red line on the breadboard.
If your led does not light up then flip your switch. If it still does not work check your wiring.
Once this is working leave the breadboard alone and move on to the perfboard.
Step 3: Soldering the Perfboard
Turn your soldering iron back on and let it warm up if you had turned it off while working on the breadboard. Unlike the breadboard, this perfboard has no hidden connections.
Components are added by sticking the leads through the non copper side and then soldering them to the copper pads on the bottom, then bending the leads so they connect to other components. We need to make the same connections as we had on the breadboard.
It is easiest to solder the perfboard if you put it in a vise, helping hands or use the Circuit Board Holder like we did.
Start with your soldered switch and put the red wire through a top hole. We chose the second hole in and the second hole away from the corner. Really any hole that makes sense will do. Now solder the wire lead to the copper or bottom side of the perfboard. Don't clip the leads just yet.
Now put the black wire through the top a couple of rows away from the red wire and solder it as well. Now add the resistor and put one lead in the same column as the red wire one or two holes away. Put the other lead through another hole in the perfboard.
Turn the perfboard over and bend the resistor lead so that it is connected to or touching the red switch lead.
In the second image above notice the two leads bent towards each other ready to be soldered. This is how we are connecting the various components.
Now solder the resistor led to the copper pad and at the same time solder the lead to the red wire lead. This may get a little messy, but that is ok as long as the 2 wires are soldered to the pads and together.
Now solder the other lead from the resistor to the copper pad. Now
add the led by inserting the long lead through the top so that it is in the same column as the resistor and only one or two holes away. Bend the lead over on the bottom so it is touching the resistor lead. At the same time stick the shorter lead through another hole several columns away.
Solder the long led lead to the copper pad and the resistor lead. Solder the other led lead to the copper pad.
Now add the two leads from the battery pack. The red wire needs to connect to the black or second wire from the switch and the black wire from the battery pack needs to connect to the led.
Put the red wire in the same column as the second switch wire and bend it over to connect to the switch lead. Do the same for the black battery pack wire and the led lead.
Solder these in place and you are done.
Step 4: Done
Here is the perfboard and the breadboard. As you can see I only had one
battery pack but still have the rest of the breadboard circuit to refer to.
So that's it. Follow a similar process on your next project and you can
always refer to the breadboard version if something isn't working right.
For more soldering information and tips, visit us at The Soldering Station.
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    13 Comments
    ok thanks the instructables works thanks
    Excellent start for a new experimenter in electronics. I would suggest a simple schematic would aid the understanding of the wiring logic. Particularly if the images showing the connected parts on the breadboard are not sharp.Also I'm sure some people might not understand the following sentence for LED connection.
    "Now connect the led short lead onto the black line and the short side to the middle of the board."
    Perhaps mention the long / short wire polarity and also the relationship of the flat edge on the LED that also defines the polarity. There are so few articles like yours that bring new people into electronics.
    Thanks for the great comment. Yes, a schematic would be good. Let me see what I can do.
    and maybe the back solderings in picture also
    that wil explain even more, becous a breadbord is also connected inside to echother, a perf board not. so you have to solder echt perf to the next one.then only top view of foto wil not show that. like you did
    so a little bit more of adding these extra`s wil make this a good basic for newbies
    then only top
    Thanks for all the great comments. What other kind of soldering or electronic Instructables would people like to see?
    I added this tutorial to my Electronics For Beginners collection. Important for hobbyists to know how to take their working prototype and put it into permanent form. Thanks for taking the time to make this available.
