loading
Picture of Breakdown Table
The Breakdown Table is a nifty kitchen table that can lose its legs and get out of town in a hurry.  It's cheap to make, easy on the eyes, and lightweight -- in short, the perfect nomadic furniture project for the guerilla designer.  Painted a bright yellow, its sure to liven up whatever kitchen you may find yourself in.  Strong enough to support your breakfasts for years to come, it's also cheap enough to leave behind if you have to.
You will need these materials:
Approx. 60" of 2" x 4"
Approx. 30" x 30" x 1-1/4" table top from old table or made from laminated plywood
Approx. 24" x 1" dia. wooden dowel or broomstick
8 2" drywall screws
8 #10 washers
Wood glue
Spray paint -- primer and topcoat
Polyurethane or similar
You will need these tools:
Circular saw
Jigsaw
Chop saw
Drill and assorted bits
Sandpaper
Speed square
Pencil
Optional:
Bandsaw
Drill press
Step 1: Legs!
The legs for this table are made out of plain ol' 2" x 4"s.  I salvaged mine out of a scrap pile.  You need two 2-bys that are about 32" long, which is generally short enough to scavenge.  Try dumpsters, alleys, pallets, and construction sites.  Worse come to worse, you can buy a piece of lumber at your local hardware store, and it shouldn't run more than three bucks.   You can even have 'em cut it for you . . .
Chop your raw material to 31-3/4" long at a 5o angle.  The angle cuts should be parallel to one another.  Connect the corner of one end with the corner of the other, striking a diagonal down the length of the piece.  Clamp to a table and cut lengthwise with a circular saw or a bandsaw.  I find a circular saw more amenable to straight cuts.  Run some 100 grit sandpaper over all the edges and cut faces.
Next, lay out the notches that will connect leg and table top.  The exact dimensions are unimportant -- you just want to keep a meaty middle piece to seat firmly in the the depth of the table top.  I made mine 2-1/4" by 1-1/2", since that meshes nicely with the dimensions of a standard 2" x 4".
The most important aspect of laying out the notches is that the horizontals are parallel to the top and bottom of the leg, i.e. at that 5o angle.  The vertical parts of the notches need to be at  90o angles to the horizontals.  All this geometry will ensure that the legs are angled but the table top is flat in the finished product.  So, measure down from the top of the leg 1-1/4" inches, or whatever the thickness of your tabletop is, and strike a horizontal.  Find the center of that line, then measure 3/4" to either side and pull a vertical.  Cut the notches out with a bandsaw or jigsaw.
Last, drill a hole the same diameter as your dowel stock that tangent to the bottom of your notches.  This will create the stabilizing bar along the underside of the table, keeping it from rocking side-to-side.  A drill press is helpful here, as those holes really need to go straight through the depth of the leg or else they'll end up crooked, and your table may list to one side.
Cut your dowels into 6" sections.  Mark a centerline, then measure 3/4" to each side of that line, smear the middle with glue, and tap into the holes in the legs.  Let dry.
Sand and slap on a couple of coats of your favorite finish.  I put down three coats of a semi-gloss polyurethane, a good, durable, easy-wipe surface in an application that may see its fair share of spills.
Good table. Color smth like in the discovery channel in program "Brain Games"
How did you cut the rectabnular holes in the table top? Thanks!
'scuse me, I meant "rectangular". :)
hi, as there doesnt seem to be a response here- 2 ways spring to mind use a morticer which is like a drill press with a square chisel which has a drill inside it (google it) alternatively they are quite large so mark the rectangles on where you want them drill a whole in each corner within the edges of your rectangle use a drill bit big enough to fit a jigsaw blade down the finished hole. then cut your square hole. hope this helps.
PS Wholman, another great ible!
Excellent!  I'm particularly enamored with your intro shot.  Absolutely perfect.
And I should make a bunch of these for stools/misc tables/nightstands.
This was a great project and really helpful instructions, thank-you!
This is great.
