3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Breakfast Express - Toy Train from toilet roll tubes
Step 6Make the engine
Make the engine
  • last photo ←
Close front-end:
• Pick a tube which has got the chimney hole
• Cut a circle from the ad paper big enough to close one end of the tube
• Close the side of the tube by gluing the circle [side which is closer to the chimney hole]
Make and Fix Chimney:
• Make a tube [chimney] from 10x10 mm ad paper to fit on to the plastic pourer
• Make few cuts [approx. 20mm deep] along the circumference on one end of the chimney
• Fix the plastic pourer into the chimney hole made on the tube. This is will help hiding the uneven cut paper and hold chimney firmly [which you would fixing in the next step]
• Insert the un-cut end of the Chimney into the plastic pourer
Driver Shed:
• Cut a strip 50 x 220 mm from the ad paper
• Using a pen, mark a point 20 mm inside from one end of the strip
• Using this point at the guide divide the other part of the strip into 4 equal parts
• Apply glue to this 2cms part and form a cube
• Apply glue to one end of this cube and stick it on opposite end of the chimney
Your engine is ready!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:ramhardikar
