Breakout Game
1,538
Posted
Introduction: Breakout Game
Here is one of my project for the Integrated Circuit Design course. The kit used for developing is FPGA SPARTAN 3E and our program is coded with using ISE XILINX DESIGN.
The basic structure of the game is easy to understand. We have as an initial frame with 3-sided, a paddle, 8 rows 96 bricks, a ball, a power-up and a power-down. There is currently one single level in the game. The main objective is to hit all the bricks on the screen by predicting the trajectory of the ball bouncing off the paddle. Bricks disappear upon contact and when there are no bricks left, the game will be over.
There are 3 modules in our project.
Step 1: First Module
module signal_generator(input clk25,
output hsyncOut,
output vsyncOut,
output [9:0] xposOut,
output [9:0] yposOut);
reg [9:0] xpos;
reg [9:0] ypos;
wire endline = (xpos == 799);
always @(posedge clk25) begin
if (endline)
xpos <= 0;
else
xpos <= xpos + 1;
end
if (endline) begin
if (ypos == 520)
ypos <= 0;
else
ypos <= ypos + 1;
end
end
reg hsync, vsync;
hsync <= ~(xpos > 664 && xpos <= 759); // active for 96 clocks
vsync <= ~(ypos == 490 || ypos == 491); // active for lines 490 and 491
end
assign hsyncOut = hsync;
assign vsyncOut = vsync;
assign xposOut = xpos;
assign yposOut = ypos;
endmodule
First module generates control signals via HS (Horizontal synchronization) and VS (Vertical synchronization).
Step 2: Second Module
module game(input clk25,
input [9:0] xpos, input [9:0] ypos, input rota, input rotb, input de, output red, output green, output blue); // paddle movement reg [8:0] paddlePosition; reg [2:0] quadAr, quadBr; always @(posedge clk25) quadAr <= {quadAr[1:0], rota}; always @(posedge clk25) quadBr <= {quadBr[1:0], rotb}; always @(posedge clk25) if(quadAr[2] ^ quadAr[1] ^ quadBr[2] ^ quadBr[1]) begin if(quadAr[2] ^ quadBr[1]) begin if(paddlePosition < 520) // movement range paddlePosition <= paddlePosition + 3 ;//velocity of the paddle end else begin if(paddlePosition >= 0) // movement range paddlePosition <= paddlePosition - 3; // velocity of the paddle end end // ball movement reg [9:0] ballX; reg [8:0] ballY; reg ballXpos, ballYpos; reg Xbounce, Ybounce; wire endOfFrame = (xpos == 0 && ypos == 480); integer b=3; always @(posedge clk25) begin if (endOfFrame) begin // update ball position at the end of each frame if (ballX == 0 && ballY == 0) begin ballX <= 25; ballY <= 280; // initial position of the ball end else begin if (ballXpos ^ Xbounce) ballX <= ballX + b; // velocity of the ball when the ball hit the right side of the border else ballX <= ballX - b; // velocity of the ball when the ball hit the left side of the border if (ballYpos ^ Ybounce) ballY <= ballY + b; //velocity of the ball when the ball hit the top of the border else ballY <= ballY - b; // velocity of the ball when the ball hit the bottom of the border end end end reg [5:0] missTimer; reg brick_alive1=1; reg brick_alive2=1; reg brick_alive3=1; reg brick_alive4=1; reg brick_alive5=1; reg brick_alive6=1; reg brick_alive7=1; reg brick_alive8=1; reg brick_alive9=1; reg brick_alive10=1; reg brick_alive11=1; reg brick_alive12=1; reg brick_alive13=1; reg brick_alive14=1; reg brick_alive15=1; reg brick_alive16=1; reg brick_alive17=1; reg brick_alive18=1; reg brick_alive19=1; reg brick_alive20=1; reg brick_alive21=1; reg brick_alive22=1; reg brick_alive23=1; reg brick_alive24=1; reg brick_alive25=1; reg brick_alive26=1; reg brick_alive27=1; reg brick_alive28=1; reg brick_alive29=1; reg brick_alive30=1; reg brick_alive31=1; reg brick_alive32=1; reg brick_alive33=1; reg brick_alive34=1; reg brick_alive35=1; reg brick_alive36=1; reg brick_alive37=1; reg brick_alive38=1; reg brick_alive39=1; reg brick_alive40=1; reg brick_alive41=1; reg brick_alive42=1; reg brick_alive43=1; reg brick_alive44=1; reg brick_alive45=1; reg brick_alive46=1; reg brick_alive47=1; reg brick_alive48=1; reg brick_alive49=1; reg brick_alive50=1; reg brick_alive51=1; reg brick_alive52=1; reg brick_alive53=1; reg brick_alive54=1; reg brick_alive55=1; reg brick_alive56=1; reg brick_alive57=1; reg brick_alive58=1; reg brick_alive59=1; reg brick_alive60=1; reg brick_alive61=1; reg brick_alive62=1; reg brick_alive63=1; reg brick_alive64=1; reg brick_alive65=1; reg brick_alive66=1; reg brick_alive67=1; reg brick_alive68=1; reg brick_alive69=1; reg brick_alive70=1; reg brick_alive71=1; reg brick_alive72=1; reg brick_alive73=1; reg brick_alive74=1; reg brick_alive75=1; reg brick_alive76=1; reg brick_alive77=1; reg brick_alive78=1; reg brick_alive79=1; reg brick_alive80=1; reg brick_alive81=1; reg brick_alive82=1; reg brick_alive83=1; reg brick_alive84=1; reg brick_alive85=1; reg brick_alive86=1; reg brick_alive87=1; reg brick_alive88=1; reg brick_alive89=1; reg brick_alive90=1; reg brick_alive91=1; reg brick_alive92=1; reg brick_alive93=1; reg brick_alive94=1; reg brick_alive95=1; reg brick_alive96=1; wire area = (xpos < 640 && ypos < 480); wire top = (area && ypos <= 10); wire bottom = (area && ypos >= 476); wire left = (area && xpos <= 3); wire right = (area && xpos >= 637); wire border = (area && (left || right || top )); // the border is adjusted. wire brick1 = ((area && xpos >= 13 && xpos <=55 && ypos<=50 && ypos>=30)&& brick_alive1); wire brick2 = ((area && xpos >= 65 && xpos <=107 && ypos<=50 && ypos>=30)&& brick_alive2); wire brick3 = ((area && xpos >= 117 && xpos <=159 && ypos<=50 && ypos>=30)&& brick_alive3); wire brick4 = ((area && xpos >= 169 && xpos <=211 && ypos<=50 && ypos>=30)&& brick_alive4); wire brick5 = ((area && xpos >= 221 && xpos <=263 && ypos<=50 && ypos>=30)&& brick_alive5); wire brick6 = ((area && xpos >= 273 && xpos <=315 && ypos<=50 && ypos>=30)&& brick_alive6); wire brick7 = ((area && xpos >= 325 && xpos <=367 && ypos<=50 && ypos>=30)&& brick_alive7); wire brick8 = ((area && xpos >= 377 && xpos <=419 && ypos<=50 && ypos>=30)&& brick_alive8); wire brick9 = ((area && xpos >= 429 && xpos <=471 && ypos<=50 && ypos>=30)&& brick_alive9); wire brick10 = ((area && xpos >= 481 && xpos <=523 && ypos<=50 && ypos>=30)&& brick_alive10); wire brick11 = ((area && xpos >= 533 && xpos <=575 && ypos<=50 && ypos>=30)&& brick_alive11); wire brick12 = ((area && xpos >= 585 && xpos <=627 && ypos<=50 && ypos>=30)&& brick_alive12); wire brick13 = ((area && xpos >= 13 && xpos <=55 && ypos<=80 && ypos>=60)&& brick_alive13); wire brick14 = ((area && xpos >= 65 && xpos <=107 && ypos<=80 && ypos>=60)&& brick_alive14); wire brick15 = ((area && xpos >= 117 && xpos <=159 && ypos<=80 && ypos>=60)&& brick_alive15); wire brick16 = ((area && xpos >= 169 && xpos <=211 && ypos<=80 && ypos>=60)&& brick_alive16); wire brick17 = ((area && xpos >= 221 && xpos <=263 && ypos<=80 && ypos>=60)&& brick_alive17); wire brick18 = ((area && xpos >= 273 && xpos <=315 && ypos<=80 && ypos>=60)&& brick_alive18); wire brick19 = ((area && xpos >= 325 && xpos <=367 && ypos<=80 && ypos>=60)&& brick_alive19); wire brick20 = ((area && xpos >= 377 && xpos <=419 && ypos<=80 && ypos>=60)&& brick_alive20); wire brick21 = ((area && xpos >= 429 && xpos <=471 && ypos<=80 && ypos>=60)&& brick_alive21); wire brick22 = ((area && xpos >= 481 && xpos <=523 && ypos<=80 && ypos>=60)&& brick_alive22); wire brick23 = ((area && xpos >= 533 && xpos <=575 && ypos<=80 && ypos>=60)&& brick_alive23); wire brick24 = ((area && xpos >= 585 && xpos <=627 && ypos<=80 && ypos>=60)&& brick_alive24); wire brick25 = ((area && xpos >= 13 && xpos <=55 && ypos<=110 && ypos>=90)&& brick_alive25); wire brick26 = ((area && xpos >= 65 && xpos <=107 && ypos<=110 && ypos>=90)&& brick_alive26); wire brick27 = ((area && xpos >= 117 && xpos <=159 && ypos<=110 && ypos>=90)&& brick_alive27); wire brick28 = ((area && xpos >= 169 && xpos <=211 && ypos<=110 && ypos>=90)&& brick_alive28); wire brick29 = ((area && xpos >= 221 && xpos <=263 && ypos<=110 && ypos>=90)&& brick_alive29); wire brick30 = ((area && xpos >= 273 && xpos <=315 && ypos<=110 && ypos>=90)&& brick_alive30); wire brick31 = ((area && xpos >= 325 && xpos <=367 && ypos<=110 && ypos>=90)&& brick_alive31); wire brick32 = ((area && xpos >= 377 && xpos <=419 && ypos<=110 && ypos>=90)&& brick_alive32); wire brick33 = ((area && xpos >= 429 && xpos <=471 && ypos<=110 && ypos>=90)&& brick_alive33); wire brick34 = ((area && xpos >= 481 && xpos <=523 && ypos<=110 && ypos>=90)&& brick_alive34); wire brick35 = ((area && xpos >= 533 && xpos <=575 && ypos<=110 && ypos>=90)&& brick_alive35); wire brick36 = ((area && xpos >= 585 && xpos <=627 && ypos<=110 && ypos>=90)&& brick_alive36); wire brick37 = ((area && xpos >= 13 && xpos <=55 && ypos<=140 && ypos>=120)&& brick_alive37); wire brick38 = ((area && xpos >= 65 && xpos <=107 && ypos<=140 && ypos>=120)&& brick_alive38); wire brick39 = ((area && xpos >= 117 && xpos <=159 && ypos<=140 && ypos>=120)&& brick_alive39); wire brick40 = ((area && xpos >= 169 && xpos <=211 && ypos<=140 && ypos>=120)&& brick_alive40); wire brick41 = ((area && xpos >= 221 && xpos <=263 && ypos<=140 && ypos>=120)&& brick_alive41); wire brick42 = ((area && xpos >= 273 && xpos <=315 && ypos<=140 && ypos>=120)&& brick_alive42); wire brick43 = ((area && xpos >= 325 && xpos <=367 && ypos<=140 && ypos>=120)&& brick_alive43); wire brick44 = ((area && xpos >= 377 && xpos <=419 && ypos<=140 && ypos>=120)&& brick_alive44); wire brick45 = ((area && xpos >= 429 && xpos <=471 && ypos<=140 && ypos>=120)&& brick_alive45); wire brick46 = ((area && xpos >= 481 && xpos <=523 && ypos<=140 && ypos>=120)&& brick_alive46); wire brick47 = ((area && xpos >= 533 && xpos <=575 && ypos<=140 && ypos>=120)&& brick_alive47); wire brick48 = ((area && xpos >= 585 && xpos <=627 && ypos<=140 && ypos>=120)&& brick_alive48); wire brick49 = ((area && xpos >= 13 && xpos <=55 && ypos<=170 && ypos>=150)&& brick_alive49); wire brick50 = ((area && xpos >= 65 && xpos <=107 && ypos<=170 && ypos>=150)&& brick_alive50); wire brick51 = ((area && xpos >= 117 && xpos <=159 && ypos<=170 && ypos>=150)&& brick_alive51); wire brick52 = ((area && xpos >= 169 && xpos <=211 && ypos<=170 && ypos>=150)&& brick_alive52); wire brick53 = ((area && xpos >= 221 && xpos <=263 && ypos<=170 && ypos>=150)&& brick_alive53); wire brick54 = ((area && xpos >= 273 && xpos <=315 && ypos<=170 && ypos>=150)&& brick_alive54); wire brick55 = ((area && xpos >= 325 && xpos <=367 && ypos<=170 && ypos>=150)&& brick_alive55); wire brick56 = ((area && xpos >= 377 && xpos <=419 && ypos<=170 && ypos>=150)&& brick_alive56); wire brick57 = ((area && xpos >= 429 && xpos <=471 && ypos<=170 && ypos>=150)&& brick_alive57); wire brick58 = ((area && xpos >= 481 && xpos <=523 && ypos<=170 && ypos>=150)&& brick_alive58); wire brick59 = ((area && xpos >= 533 && xpos <=575 && ypos<=170 && ypos>=150)&& brick_alive59); wire brick60 = ((area && xpos >= 585 && xpos <=627 && ypos<=170 && ypos>=150)&& brick_alive60); wire brick61 = ((area && xpos >= 13 && xpos <=55 && ypos<=200 && ypos>=180)&& brick_alive61); wire brick62 = ((area && xpos >= 65 && xpos <=107 && ypos<=200 && ypos>=180)&& brick_alive62); wire brick63 = ((area && xpos >= 117 && xpos <=159 && ypos<=200 && ypos>=180)&& brick_alive63); wire brick64 = ((area && xpos >= 169 && xpos <=211 && ypos<=200 && ypos>=180)&& brick_alive64); wire brick65 = ((area && xpos >= 221 && xpos <=263 && ypos<=200 && ypos>=180)&& brick_alive65); wire brick66 = ((area && xpos >= 273 && xpos <=315 && ypos<=200 && ypos>=180)&& brick_alive66); wire brick67 = ((area && xpos >= 325 && xpos <=367 && ypos<=200 && ypos>=180)&& brick_alive67); wire brick68 = ((area && xpos >= 377 && xpos <=419 && ypos<=200 && ypos>=180)&& brick_alive68); wire brick69 = ((area && xpos >= 429 && xpos <=471 && ypos<=200 && ypos>=180)&& brick_alive69); wire brick70 = ((area && xpos >= 481 && xpos <=523 && ypos<=200 && ypos>=180)&& brick_alive70); wire brick71 = ((area && xpos >= 533 && xpos <=575 && ypos<=200 && ypos>=180)&& brick_alive71); wire brick72 = ((area && xpos >= 585 && xpos <=627 && ypos<=200 && ypos>=180)&& brick_alive72); wire brick73 = ((area && xpos >= 13 && xpos <=55 && ypos<=230 && ypos>=210)&& brick_alive73); wire brick74 = ((area && xpos >= 65 && xpos <=107 && ypos<=230 && ypos>=210)&& brick_alive74); wire brick75 = ((area && xpos >= 117 && xpos <=159 && ypos<=230 && ypos>=210)&& brick_alive75); wire brick76 = ((area && xpos >= 169 && xpos <=211 && ypos<=230 && ypos>=210)&& brick_alive76); wire brick77 = ((area && xpos >= 221 && xpos <=263 && ypos<=230 && ypos>=210)&& brick_alive77); wire brick78 = ((area && xpos >= 273 && xpos <=315 && ypos<=230 && ypos>=210)&& brick_alive78); wire brick79 = ((area && xpos >= 325 && xpos <=367 && ypos<=230 && ypos>=210)&& brick_alive79); wire brick80 = ((area && xpos >= 377 && xpos <=419 && ypos<=230 && ypos>=210)&& brick_alive80); wire brick81 = ((area && xpos >= 429 && xpos <=471 && ypos<=230 && ypos>=210)&& brick_alive81); wire brick82 = ((area && xpos >= 481 && xpos <=523 && ypos<=230 && ypos>=210)&& brick_alive82); wire brick83 = ((area && xpos >= 533 && xpos <=575 && ypos<=230 && ypos>=210)&& brick_alive83); wire brick84 = ((area && xpos >= 585 && xpos <=627 && ypos<=230 && ypos>=210)&& brick_alive84); wire brick85 = ((area && xpos >= 13 && xpos <=55 && ypos<=260 && ypos>=240)&& brick_alive85); wire brick86 = ((area && xpos >= 65 && xpos <=107 && ypos<=260 && ypos>=240)&& brick_alive86); wire brick87 = ((area && xpos >= 117 && xpos <=159 && ypos<=260 && ypos>=240)&& brick_alive87); wire brick88 = ((area && xpos >= 169 && xpos <=211 && ypos<=260 && ypos>=240)&& brick_alive88); wire brick89 = ((area && xpos >= 221 && xpos <=263 && ypos<=260 && ypos>=240)&& brick_alive89); wire brick90 = ((area && xpos >= 273 && xpos <=315 && ypos<=260 && ypos>=240)&& brick_alive90); wire brick91 = ((area && xpos >= 325 && xpos <=367 && ypos<=260 && ypos>=240)&& brick_alive91); wire brick92 = ((area && xpos >= 377 && xpos <=419 && ypos<=260 && ypos>=240)&& brick_alive92); wire brick93 = ((area && xpos >= 429 && xpos <=471 && ypos<=260 && ypos>=240)&& brick_alive93); wire brick94 = ((area && xpos >= 481 && xpos <=523 && ypos<=260 && ypos>=240)&& brick_alive94); wire brick95 = ((area && xpos >= 533 && xpos <=575 && ypos<=260 && ypos>=240)&& brick_alive95); wire brick96 = ((area && xpos >= 585 && xpos <=627 && ypos<=260 && ypos>=240)&& brick_alive96);
/// integer a=4; wire paddle = (xpos >= paddlePosition+4 && xpos <= paddlePosition+80+a && ypos >= 440 && ypos <= 447); //paddle x en büyüklüğü , y boyu wire ball = (xpos >= ballX && xpos <= ballX+5 && ypos >= ballY && ypos <= ballY+5); // ball sizes wire background = (area && !(border || paddle || ball)); wire missed = area && missTimer != 0;
assign red = { missed || border || paddle || ball || brick1 || brick2 || brick3 || brick4 || brick5 || brick6 || brick7 || brick8 || brick9 || brick10 || brick11 || brick12 || brick13 || brick14 || brick15 || brick16 || brick17 || brick18 || brick19 || brick20 || brick21 || brick22 || brick23 || brick24 || brick73 || brick74 || brick75 || brick76 || brick77 || brick78 || brick79 || brick80 || brick81 || brick82 || brick83 || brick84 || brick85 || brick86 || brick87 || brick88 || brick89 || brick90 || brick91 || brick92 || brick93 || brick94 || brick95 || brick96}; assign green = { missed || border || paddle ||ball || brick25 || brick26 || brick27 || brick28 || brick29 || brick32 || brick33 || brick34 || brick35 || brick36 || brick37 || brick38 || brick39 || brick40 || brick41 || brick42 || brick43 || brick44 || brick45 || brick46 || brick47 || brick48 || brick49 || brick50 || brick51 || brick52 || brick53 || brick54 || brick55 || brick56 || brick57 || brick58 || brick59 || brick60 || brick61 || brick62 || brick63 || brick64 || brick65 || brick66 || brick67 || brick68 || brick69 || brick70 || brick71 || brick72 || brick73 || brick74 || brick75 || brick76 || brick77 || brick78 || brick79 || brick80 || brick81 || brick82 || brick83 || brick84 || brick85 || brick86 || brick87 || brick88 || brick89 || brick90 || brick91 || brick92 || brick93 || brick94 || brick95 || brick96 }; assign blue = { missed || border || paddle || ball || brick25 || brick26 || brick27 || brick28 || brick29 || brick30 || brick31 || brick32 || brick33 || brick34 || brick35 || brick36 || brick37 || brick38 || brick39 || brick40 || brick41 || brick42 || brick43 || brick44 || brick45 || brick46 || brick47 || brick48}; // ball collision always @(posedge clk25) begin if (!endOfFrame) begin if (ball && (left || right)) Xbounce <= 1; if (ball && (top || bottom || (paddle && ballYpos))) Ybounce <= 1; if (ball && bottom) missTimer <= 60; if (de==1'b1) begin a=4; b=3; brick_alive1=1; brick_alive2=1; brick_alive3=1; brick_alive4=1; brick_alive5=1; brick_alive6=1; brick_alive7=1; brick_alive8=1; brick_alive9=1; brick_alive10=1; brick_alive11=1; brick_alive12=1; brick_alive13=1; brick_alive14=1; brick_alive15=1; brick_alive16=1; brick_alive17=1; brick_alive18=1; brick_alive19=1; brick_alive20=1; brick_alive21=1; brick_alive22=1; brick_alive23=1; brick_alive24=1; brick_alive25=1; brick_alive26=1; brick_alive27=1; brick_alive28=1; brick_alive29=1; brick_alive30=1; brick_alive31=1; brick_alive32=1; brick_alive33=1; brick_alive34=1; brick_alive35=1; brick_alive36=1; brick_alive37=1; brick_alive38=1; brick_alive39=1; brick_alive40=1; brick_alive41=1; brick_alive42=1; brick_alive43=1; brick_alive44=1; brick_alive45=1; brick_alive46=1; brick_alive47=1; brick_alive48=1; brick_alive49=1; brick_alive50=1; brick_alive51=1; brick_alive52=1; brick_alive53=1; brick_alive54=1; brick_alive55=1; brick_alive56=1; brick_alive57=1; brick_alive58=1; brick_alive59=1; brick_alive60=1; brick_alive61=1; brick_alive62=1; brick_alive63=1; brick_alive64=1; brick_alive65=1; brick_alive66=1; brick_alive67=1; brick_alive68=1; brick_alive69=1; brick_alive70=1; brick_alive71=1; brick_alive72=1; brick_alive73=1; brick_alive74=1; brick_alive75=1; brick_alive76=1; brick_alive77=1; brick_alive78=1; brick_alive79=1; brick_alive80=1; brick_alive81=1; brick_alive82=1; brick_alive83=1; brick_alive84=1; brick_alive85=1; brick_alive86=1; brick_alive87=1; brick_alive88=1; brick_alive89=1; brick_alive90=1; brick_alive91=1; brick_alive92=1; brick_alive93=1; brick_alive94=1; brick_alive95=1; brick_alive96=1; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=50 && ypos>=30)) brick_alive1 = 0; if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=50 && ypos>=30)) brick_alive2=0; if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=50 && ypos>=30)) brick_alive3=0; if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=50 && ypos>=30)) brick_alive4=0; if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=50 && ypos>=30)) brick_alive5=0; if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=50 && ypos>=30)) brick_alive6=0; if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=50 && ypos>=30)) begin brick_alive7=0; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=50 && ypos>=30)) begin brick_alive8=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=50 && ypos>=30)) begin brick_alive9=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=50 && ypos>=30)) begin brick_alive10=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=50 && ypos>=30)) begin brick_alive11=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=50 && ypos>=30)) begin brick_alive12=0; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=80 && ypos>=60))begin brick_alive13 = 0; end if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=80 && ypos>=60)) begin brick_alive14=0; end if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=80 && ypos>=60))begin brick_alive15=0; end if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=80 && ypos>=60)) begin brick_alive16=0; end if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=80 && ypos>=60)) begin brick_alive17=0; end if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=80 && ypos>=60)) begin brick_alive18=0; end if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=80 && ypos>=60)) begin brick_alive19=0; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=80 && ypos>=60)) begin brick_alive20=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=80 && ypos>=60)) begin brick_alive21=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=80 && ypos>=60)) begin brick_alive22=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=80 && ypos>=60)) begin brick_alive23=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=80 && ypos>=60)) begin brick_alive24=0; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=110 && ypos>=90)) begin brick_alive25 = 0; end if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=110 && ypos>=90)) begin brick_alive26=0; end if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=110 && ypos>=90))begin brick_alive27=0; end if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=110 && ypos>=90)) begin brick_alive28=0; end if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=110 && ypos>=90)) begin brick_alive29=0; end if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=110 && ypos>=90)) begin brick_alive30=0; a=40; end if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=110 && ypos>=90)) begin brick_alive31=0; b=5; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=110 && ypos>=90)) begin brick_alive32=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=110 && ypos>=90)) begin brick_alive33=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=110 && ypos>=90)) begin brick_alive34=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=110 && ypos>=90)) begin brick_alive35=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=110 && ypos>=90)) begin brick_alive36=0; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=140 && ypos>=120))begin brick_alive37 = 0; end if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=140 && ypos>=120)) begin brick_alive38=0; end if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=140 && ypos>=120))begin brick_alive39=0; end if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=140 && ypos>=120)) begin brick_alive40=0; end if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=140 && ypos>=120)) begin brick_alive41=0; end if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=140 && ypos>=120)) begin brick_alive42=0; end if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=140 && ypos>=120)) begin brick_alive43=0; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=140 && ypos>=120)) begin brick_alive44=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=140 && ypos>=120)) begin brick_alive45=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=140 && ypos>=120)) begin brick_alive46=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=140 && ypos>=120)) begin brick_alive47=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=140 && ypos>=120)) begin brick_alive48=0; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=170 && ypos>=150)) begin brick_alive49 = 0; end if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=170 && ypos>=150)) begin brick_alive50=0; end if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=170 && ypos>=150))begin brick_alive51=0; end if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=170 && ypos>=150)) begin brick_alive52=0; end if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=170 && ypos>=150)) begin brick_alive53=0; end if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=170 && ypos>=150)) begin brick_alive54=0; end if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=170 && ypos>=150)) begin brick_alive55=0; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=170 && ypos>=150)) begin brick_alive56=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=170 && ypos>=150)) begin brick_alive57=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=170 && ypos>=150)) begin brick_alive58=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=170 && ypos>=150)) begin brick_alive59=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=170 && ypos>=150)) begin brick_alive60=0; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=200 && ypos>=180)) begin brick_alive61 = 0; end if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=200 && ypos>=180)) begin brick_alive62=0; end if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=200 && ypos>=180))begin brick_alive63=0; end if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=200 && ypos>=180)) begin brick_alive64=0; end if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=200 && ypos>=180)) begin brick_alive65=0; end if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=200 && ypos>=180)) begin brick_alive66=0; end if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=200 && ypos>=180)) begin brick_alive67=0; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=200 && ypos>=180)) begin brick_alive68=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=200 && ypos>=180)) begin brick_alive69=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=200 && ypos>=180)) begin brick_alive70=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=200 && ypos>=180)) begin brick_alive71=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=200 && ypos>=180)) begin brick_alive72=0; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=230 && ypos>=210)) begin brick_alive73 =0; end if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=230 && ypos>=210)) begin brick_alive74=0; end if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=230 && ypos>=210))begin brick_alive75=0; end if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=230 && ypos>=210)) begin brick_alive76=0; end if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=230 && ypos>=210)) begin brick_alive77=0; end if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=230 && ypos>=210)) begin brick_alive78=0; end if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=230 && ypos>=210)) begin brick_alive79=0; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=230 && ypos>=210)) begin brick_alive80=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=230 && ypos>=210)) begin brick_alive81=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=230 && ypos>=210)) begin brick_alive82=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=230 && ypos>=210)) begin brick_alive83=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=230 && ypos>=210)) begin brick_alive84=0; end if (ball && (area && xpos >= 13 && xpos <=55 && ypos<=260 && ypos>=240)) begin brick_alive85 = 0; end if (ball && (area && xpos >= 65 && xpos <=107 && ypos<=260 && ypos>=240)) begin brick_alive86=0; end if (ball&& (area && xpos >= 117 && xpos <=159 && ypos<=260 && ypos>=240))begin brick_alive87=0; end if ( ball && (area && xpos >= 169 && xpos <=211 && ypos<=260 && ypos>=240)) begin brick_alive88=0; end if ( ball && (area && xpos >= 221 && xpos <=263 && ypos<=260 && ypos>=240)) begin brick_alive89=0; end if ( ball&& (area && xpos >= 273 && xpos <=315 && ypos<=260 && ypos>=240)) begin brick_alive90=0; end if (ball&& (area && xpos >= 325 && xpos <=367 && ypos<=260 && ypos>=240)) begin brick_alive91=0; end if ( ball&& (area && xpos >= 377 && xpos <=419 && ypos<=260 && ypos>=240)) begin brick_alive92=0; end if ( ball&& (area && xpos >= 429 && xpos <=471 && ypos<=260 && ypos>=240)) begin brick_alive93=0; end if ( ball && (area && xpos >= 481 && xpos <=523 && ypos<=260 && ypos>=240)) begin brick_alive94=0; end if ( ball && (area && xpos >= 533 && xpos <=575 && ypos<=260 && ypos>=240)) begin brick_alive95=0; end if ( ball && (area && xpos >= 585 && xpos <=627 && ypos<=260 && ypos>=240)) begin brick_alive96=0; end end else begin if (ballX == 0 && ballY == 0) begin ballXpos <= 1; ballYpos <= 1; Xbounce <= 0; Ybounce <= 0; end else begin if (Xbounce) ballXpos <= ~ballXpos; if (Ybounce) ballYpos <= ~ballYpos; Xbounce <= 0; //0 yapınca X düzlemi üzerindeki hareketi serbestleşiyor, 1 yaparsak başlangıç noktasına sabitleniyor. Ybounce <= 0; //0 yapınca Y düzlemi üzerindeki hareketi serbestleşiyor, 1 yaparsak başlangıç noktasına sabitleniyor. if (missTimer != 0) missTimer <= missTimer - 1; end end end endmodule
Step 3: 3rd Module
module breakout(
input clk50, input rota, input rotb, input de, output red, output green, output blue, output hsync, output vsync ); reg clk25_int; always @(posedge clk50) begin clk25_int <= ~clk25_xx; end wire clk25; BUFG bufg_inst(clk25, clk25_xx); wire [9:0] xpos; wire [9:0] ypos; signal_generator signal_generator_inst(clk25, hsync, vsync, xpos, ypos); game game_inst(clk25, xpos, ypos, rota, rotb,de, red, green, blue);
endmodule
In third module, first and second modules are called. Also a buffer is used for clk.
Step 4: .ucf Document
NET "clk50" LOC ="C9"  | IOSTANDARD = LVCMOS33;                                                   NET "hsync" LOC = "F15"
| IOSTANDARD = LVTTL | DRIVE = 8 | SLEW = FAST ;                                              NET "vsync" LOC = "F14"
| IOSTANDARD = LVTTL | DRIVE = 8 | SLEW = FAST  ;                                          NET "red"   LOC = "H14" | IOSTANDARD = LVTTL |
DRIVE = 8 | SLEW = FAST ;                                            NET "green" LOC = "H15"
| OSTANDARD = LVTTL | DRIVE = 8 | SLEW = FAST ;                                              NET "blue"  LOC = "G15" | IOSTANDARD = LVTTL |
DRIVE = 8 | SLEW = FAST ;                                            NET "rota"   LOC = "K18" | IOSTANDARD = LVTTL |
PULLUP   ;        NET "rotb"    LOC = "G18" | IOSTANDARD = LVTTL
| PULLUP ;        NET "de"  LOC = "H13" | IOSTANDARD = LVTTL |
PULLDOWN ;
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    2 Comments
    Very nice! Thanks for sharing your code for this game.
    Thank you for posting me. I hope you enjoy :)
