Breathalyzer Microphone by randofo
Featured
The breathalyzer microphone is a system for the inconscpicuous collection of blood-alcohol content level data sets. In other words, you can measure a person's sobriety with a device, that for all intents and purposes, looks no different than a standard microphone. This tool adds new dimensions of truthiness to any standard interview. It can also easily be adapted for karaoke.
Don't be intimated by the number of steps. It's one of the least complicated projects I've ever made.
This project was initially developed with the love and support of the Eyebeam OpenLab.
Step 1: Go get stuff
You will need:
- A MQ-3 Alcohol Sensor (available via Futurlec. Allow a few weeks for shipping from Thailand. Be warned! Ordering anything else from Futurlec may place your order on backorder and leave you waiting a long, long, time without being notified).
- An XLR microphone (you can pick up cheap dynamic XLR microphones intended for karaoke all over the internet)
- An Arduino Decimilla
- Logomatic Data Logger (via Sparkfun)
- An SD Card (can get a cheap 256MB card at Radioshack)
- An SD Card reader
- XLR to 1/4" stereo plug
- A professional-looking audio device (working or not)
- resistors (100K, 10K, 1K)
- a schottky diode
- Acrylic or cardboard
- glue
- solid hookup wire
- 9V battery plug
- 9V battery
- isopropyl rubbing alcohol
- a 12 pack and some friends
(other stuff for interfacing Arduino and data logger?)
Tools:
Soldering iron
Wire cutters
Mini screwdriver set
Needle nose pliers
multimeter
Power drill or other rotary tool
Scissors, saw and/or laser cutter (see step 15)
Step 2: Remove the wind screen
Simply twist the windscreen counter clockwise and it should unscrew right off.
Step 3: Loosen the Mic
Loosen the mic from the casing by twisting them apart gently. That means that you need to simultaneously pull and twist to separate the two. The mic is usually glued in, but never well enough that can't be defeated by some gentle force.
Step 4: Take out the switch
To remove the switch from the casing, the on off label has to be carefully peeled up. Be careful not to bend or destroy it, since you will be putting it back in place later. The best way to removed it is with a small flathead screwdriver or a safety pin.
Once the label is removed, there should be two screws. Unscrew these screws to free the switch from the case.
Set aside the label and screws for reassembly later. If you lose these, you won't be able to reassemble this easily.
Step 5: Remove the XLR plug
Locate the screw at the bottom of the casing. This is holding the XLR plug in place. Unscrew this screw as well to free the XLR plug. Once you are done, set this screw aside.
Step 6: Take out the wiring
All of the microphone's components should now be free from the casing. Gently pull on the microphone element to remove all the wiring from the casing.
Step 7: Prepare the XLR plug
The XLR plug in most cases is probably setup for mono audio output. This usually means that two of the pins are grounded (notice in the secondary image how two round pins are connected to the flat ground tab).
For the purpose we are using the XLR plug, only one pin should be grounded. This means that the two round pins should no longer be connected. Take your wire cutters and cut away this connection. Bend any extra wire on these pins away from each other.
Step 8: Prepare the switch
Preparing the switch is easy. Only the red wire coming from the XLR plug should remain connected to the switch. Cut away all extra wires with your wire cutter.
By doing this, you have just cut free the microphone element. This is a perfectly good microphone and element and could be used for a host of other projects. Store it away somewhere safe.
Step 9: Attach more wires to the XLR plug
Attach a wire that is about 8" long to the one pin on the XLR plug that is no longer connected to anything.
Also, take your wire cutters and remove the remove the remaining black wire. Replace that black wire with another black wire that is 8" long.
Step 10: Attach more wires to the switch
Attach a red wire that is about 6" long to the tab on the switch that used to be connected to the microphone, but to which no wires are currently connected.
A good way to figure out which is the right tab is by figuring out which two tabs the slider button is directly above when the microphone is turned on. It is these two tabs that need wires connected to them. One should already have a wire connected to it (probably the center one). It is the bottom tab that needs to have a wire connected to it (there should already be some solder on the pin, since you cut a wire off of it earlier). If you are still confused, just look at the pictures below.
Step 11: Reassemble
Reinsert the wiring into the microphone casing starting with the XLR plug. The XLR plug probably needs to be orientated in the right direction to be able to slide in. Look for guides on the side of the plug that need to be lined up right.
It helps to push the XLR plug as far as you can in using your fingers and then to pull it through with a pair of needle nose pliers.
Line it up correctly, and reinsert the screw you removed earlier.
Next, hold the switch in place with your finger and screw that in as well. Once that is screwed in place, stick the "on/off" label back on.
Make sure that the switch is orientated correctly with the label. In other words, when the switch is put in the "on" position, it should be sitting directly over the two tabs with wires attached to it.
Step 12: Test your connections
There should now have 3 wires sticking out of the top of your microphone casing. If it hasn't been done already, strip about an inch of plastic off the ends of each of these wires.
Using the continuity tester on your multimeter (normally has a picture of a diode next to it) touch one probe to one of the pins on your XLR plug and then, one at a time, touch each wire at the other end. For each pin, there should only be on corresponding wire that gives a positive reading of being connected.
If more than one wire gives you a positive reading, you need to remove everything once more and check the connections.
Also, if you find a pin that does not seem to be connected to any wires, try turning the switch on. If that still doesn't work, you need to disassemble and re-check your work.
Speaking of the switch, be extra careful to make sure that the switch both turns on and off.
Step 13: Prepare the stereo plug
Cut two red wires and one black wire of about 6" length. The black wire should be connected ____. The red wires should go to the other two ______.
Step 14: Test your connections... again
Before all of the components are soldered in place on the microphone, it would be ideal to determine which wire is going where when the XLR cable is connected.
So, first of all, connect the XLR cable to the microphone. Connect the other end of the cable to the 1/4" plug.
With the continuity tester on your multimeter test to make certain that the black wire connected to the 1/4" plug makes a connection with the other black wire coming out the top of the microphone.
Next determine which red wire coming from the 1/4" plug corresponds to the red wire coming out of the top of the microphone that is connected to the switch. This is easy to test because when the switch is turned on, they should make a connection and when the switch is turned off, the connection should be broken. Once you found these two wires, mark them with a piece of tape.
For good measure, double check that the other two red wires that aren't marked also make a connection when tested with your multimeter.
Step 15: Mounting Bracket
Attached is a file for a mounting bracket which will fit snugly inside the opening in top of the microphone (at least my microphone). You may need to adjust the diameter of the outside circle to be sized correctly for your microphone.
This file is set up for a laser cutter and can be used to cut out the bracket in seconds should you be lucky enough to have access to a laser cutter.
If, like most people, you don't have access to a laser cutter, this file is still very helpful to you. You can print it out on any sheet of computer paper and then cut out the outer circle with a pair of scissors. Once this is done, tape this circle to whatever material you wish to make this bracket out of. Once its taped down, use this as a guide to cut out a circle and drill holes. I recommend using wood, acrylic or a thin, sturdy, board-like material.
Step 16: Start soldering
Pick one side of the bracket to be the top and insert resistors through the outter holes so that one sits nicely on each side (forming a V-shape).
Twist together the two closest metal leads and then connect them with solder.
Step 17: Finish soldering
On the side of the bracket upon which you inserted the resistors, insert the alcohol sensor.
Flip over the bracket. There are two groupings of three pins coming from the sensor.
For the first grouping of three pins, you are going to want to connect one of the outside leads from the resistors to one of the outside pins in the group. Then, you will need to solder the other resistor lead to the middle pin.
Once those connections are made you will need to solder the wires from the microphone. Solder the black wire also to the middle pin. If it is easier, you can also solder it to resistor lead connected to the middle pin.
Next, solder the red wire that is not connected to the power switch to the other outside pin that resistor lead is connected to.
Lastly, it is now time to connect the red wire coming from the power switch to the sensor. This wire gets connected to the grouping of three pins that you have yet to connect wires to (the one furthest from the resistors). Simply wrap this wire around either of the two outter pins and the center pin and then, in turn, solder it to the outter and center pin.
Step 18: Glue the bracket in place
Position the bracket neatly in place. If this looks good, take it back out of place, put some glue on the sides/underside and put it back once more. Try to keep from getting glue in the treads for the windscreen or you'll never get it back on.
If you sized your bracket right, you won't need all too much glue to hold it in place, since it should stay pretty securely on its own.
Step 19: Put the windscreen back on
Once the glue is dry, put the windscreen back on by twisting it on clockwise.
Step 20: Make a discreet datalogger
To make your mic truly portable, you will need to make a discreet datalogger as seen in this Instructable.
Step 21: Program the Arduino
Below is the code needed to test the Arduino.
First, open the Arduino development environment. Next, load up the file found below. Lastly hit the "upload" button.
Note: Older version of the Arduino may require hitting the restart button first before uploading
Step 22: Testing... Testing... Is this thing on?
I found the easiest way to simply make sure that its working is to turn on the serial monitor, wet a napkin with isopropyl alcohol, place the napkin near the windscreen of the mic and to blow. This should increase the resistance on the microphone and make the numbers that you are seeing increase.
If you really want to test it, you are going to need to get some beers and a couple of friends. Monitor their alcohol intake. Vary the rate at which they are drinking. Also, take note of their height and weight to accurately calculate their intoxication level.
Or... you could just bring it to an art opening and see what happens.
Step 23: Taking a reading
To take a reading, approach your subject and turn the microphone on at least one minute before having them speak into it. About thirty seconds into the reading turn the microphone off to take a string of "zero" readings. This is important because it is the initial reading taken within the first thirty seconds that you need to clearly delineate.
Once you turn the microphone back on, it probably will no longer be completely accurate and need some time to reset.
Step 24: Reading the SD card
To see the readings, just open your SD card on a computer and view the text files.
The readings are the spikes in numbers in your text file
Step 25: Have some fun
If you have a mac, you can plug your Arduino and microphone in the USB port and run the program found below for a fun time.
1-40 of 43Next »
Giedow says: Feb 3, 2013. 10:27 AM
Now explain to me how a mic analyses your breath for alcohol
randofo (author) says: Feb 4, 2013. 9:45 AM
The alcohol sensor does this.
Giedow says: Feb 4, 2013. 11:41 AM
that is a valid point
amandaghassaei says: Nov 11, 2012. 3:19 PM
this is hilarious randy. every sunday is karaoke night at the bar across the street from my apartment, I'd love to use this as some kind of kill switch on the audio system, get those crazies off the mic faster...
evix says: Dec 5, 2009. 4:27 PM
It'd be great to interface this with a karaoke, or rock band mic!
oweng4000 says: Mar 19, 2011. 10:20 AM
And then set up the mic at your local bar's karaoke night.
Warlrosity says: Apr 30, 2009. 2:58 AM
Can you do it with a cheapie breth tinig
FeedTheGrid says: Apr 14, 2009. 2:53 AM
Rad!
DarkAngel09 says: Oct 29, 2008. 5:06 AM
Is there anywhere else you can get the alcohol sensor besides in Thailand I do not have that amount of time and i want to try and build this microphone
armyofgnomes says: Mar 14, 2009. 10:56 AM
randofo (author) says: Oct 30, 2008. 10:04 AM
Not that I know of, but you can get the datasheet off the website and probably pull a part number off of there. Then you can just do a google search for it. I won't say its impossible, but it may be hard to track down. If you pay an extra $16 in shipping (or so) you can get it much sooner.
DarkAngel09 says: Nov 3, 2008. 1:41 PM
Cool. do you think you could explain how it works i'm thinking of building the sensor myself...even though i may epicly fail at it.
armyofgnomes says: Mar 14, 2009. 10:55 AM
Did you have to "preheat" the alcohol gas sensor? I just received mine and it started off in the 1000 range. I've had it plugged in for about an hour or two now and it's down to the 800 range. The datasheet mentions a 24 hour preheat time. I think the normal range is supposed to be from 160 to 1024.
Redgerr says: Aug 8, 2008. 7:51 AM
wow, i like the idea a lot... ill have to be careful next time i take an interview :O make sure this isnt in there >:O i hope they dont catch me :P
uhh, jk btw i dont drink :)
DarkAngel09 says: Oct 29, 2008. 8:57 AM
youprobably do and dont know it
baneat says: Aug 15, 2008. 12:00 PM
If someone's drunk enough to try singing into it, you'll know lol. No breathalyser needed.
chalky says: Aug 8, 2008. 6:59 AM
just think how easily this could be 'hooked up' and Incorporated into a vehicle so the ignition would not start if the drivers pi$$ed! GENIOUS!!!
Dandy in the Ghetto says: Aug 14, 2008. 5:23 PM
It's called an "ignition interlock device". In Arizona you have to get one installed in your car if you get pulled over and blow positive for alcohol, even if your BAC was under the legal limit.
Nesagwa says: Aug 8, 2008. 12:22 PM
They have those already.
juggalo_assassin183 says: Aug 8, 2008. 10:49 PM
i know somebody with one she says its a real pain and likes to break but she still likes it beter the losing her licence lol
antennas says: Aug 8, 2008. 11:34 AM
Just so long as you realize that this won't be terribly accurate. It takes deep lung air to get an accurate reading of blood alcohol content, not the air that would go over the mic while talking. BUT it does sound like a fun toy at parties, but nothing more.
randofo (author) says: Aug 9, 2008. 11:22 AM
Indeed. Right now accuracy is my largest problem. However, I'd like to get it to a point where I have calibrated and tested it enough to be able to claim an approximate BAC level range.
rickfmdj says: Aug 8, 2008. 5:29 AM
Cool and LMAO!
mr_step says: Aug 6, 2008. 6:14 PM
(removed by author or community request)
rotinaj says: Aug 7, 2008. 10:38 PM
Or if there's a correlation between ingesting alcohol and thinking karaoke is a good idea.
la says: Aug 7, 2008. 3:12 PM
... or to see if there's a correlation between GOOD singing and alcohol content... ;)
la says: Aug 7, 2008. 5:14 PM
definitely chiundogu - worthy
darkmuskrat says: Aug 6, 2008. 11:08 PM
*laughing so hard right now*
AnarchistAsian says: Aug 7, 2008. 5:51 PM
how covert... *adds this to spy gizmos group* i give it a 4.5!
hunrichs says: Aug 7, 2008. 4:55 PM
oh this is great!. further modification that might be fun would be to make a version where the recorder actually ONLY works above a certain BAC threshold. less useful, perhaps, but guaranteed to result in consistent silliness.
jon123321 says: Aug 6, 2008. 7:23 PM
pyro222 says: Aug 7, 2008. 4:11 PM
hahaha LOL. Aint that the truth.
gmoon says: Aug 7, 2008. 10:18 AM
Might-ie cool. Can the Arduino fetch data from the logger, or is the logger itself write-only? (you can read the card, of course, externally.)
Lithium Rain says: Aug 7, 2008. 6:48 AM
Wow! You finally did it! I've been waiting for this for a long time! 5*s and faved.
RyanPotter says: Aug 6, 2008. 11:31 PM
Dude, right off the bat you earned 5 stars for using the word 'truthiness' and second, this is a brilliant idea! I see big karaoke applications for this device.
bumpus says: Aug 6, 2008. 5:06 PM
Excellent Randy!
This would be quite the project to take to school....
:D
"TRUTHINESS"
Hooray for Colbert!
pyro222 says: Aug 6, 2008. 4:40 PM
hehe, you said truthiness... Nice! Very cool tut!
zachninme says: Jun 2, 2008. 6:02 PM
Awesome job Randy! What's the output from the sensor, analog? I like the laser-cut circuit templates. Did you have any problems with them, such as burning the plastic w/ your soldering iron?
randofo (author) says: Jun 3, 2008. 12:49 PM
How did you find this? I didn't publish it yet :) The sensor is a really basic and relatively stable analog sensor. The soldering worked alright. The acrylic doesn't melt too easily and the connections were made quickly and slightly over the surface of the plastic, so it wasn't too large of a problem.
1-40 of 43Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
