Step 10Attach more wires to the switch
A good way to figure out which is the right tab is by figuring out which two tabs the slider button is directly above when the microphone is turned on. It is these two tabs that need wires connected to them. One should already have a wire connected to it (probably the center one). It is the bottom tab that needs to have a wire connected to it (there should already be some solder on the pin, since you cut a wire off of it earlier). If you are still confused, just look at the pictures below.
Add Comment
