3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Breathalyzer Microphone
Step 15Mounting Bracket
Mounting Bracket
Attached is a file for a mounting bracket which will fit snugly inside the opening in top of the microphone (at least my microphone). You may need to adjust the diameter of the outside circle to be sized correctly for your microphone.
This file is set up for a laser cutter and can be used to cut out the bracket in seconds should you be lucky enough to have access to a laser cutter.
If, like most people, you don't have access to a laser cutter, this file is still very helpful to you. You can print it out on any sheet of computer paper and then cut out the outer circle with a pair of scissors. Once this is done, tape this circle to whatever material you wish to make this bracket out of. Once its taped down, use this as a guide to cut out a circle and drill holes. I recommend using wood, acrylic or a thin, sturdy, board-like material.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2333
Author:randofo(Randy Sarafan loves you!)
I am the Technology Editor here at Instructables. I am also the author of the books 'Simple Bots,' and '62 Projects to Make with a Dead Computer'. Subscribing to me = fun and excitement!
