3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Breech Loaded Airsoft Blowgun!
This is my breech loaded airsoft blowgun. I put it together in about 15-20 mins, so be expecting updates in the near future(later today).
Step 1Materials
This is what you need(Duh)
1.)Pen barell(airsoft barell for over achievers)
2.)Highlighter cap that fits snugly around pen barell
3.)Leatherman, Multi-tool, whatever you want to call it
4.)Electrical tape(any kind will work, as long as it is about a half inch wide)
5.)Airsoft BB's
6.)Mp3 player(i used mine for lighting and a stand for the vid)
15 comments
Dec 23, 2010. 4:04 PMThe Incredible IT Maker says:
i just use the twisty rod from window blinds, cut off the tips, and load a handfull in my mouth. it has really good range too. good idea though
Jul 23, 2008. 10:57 AMlupinesoul says:
There's a problem. What if you need to fire 91-269 degrees when up is 0 or 360 (for the simple-minded, down). The pellet just rolls out of the barrel.
Aug 4, 2009. 11:43 PMH3xx says:
First of all, I know this is an old post but i have an answer. simply use steel bbs, and attach a magnet to the barrel (assuming your adding a breach to an altoids blowgun, inside the container, on the opposite side of the ammo.) make sure the magnet is strong enough to hold a bb through the barrel, but weak enough to be able to blow it loose. the latter shouldn't be difficult if the barrel is snug enough around the bb. I'm sure I don't have to say this, but using steel bbs makes this setup much more dangerous, and should never be fired at a person (or pet). This would be great for keeping stray animals out of the yard, or hunting pigeons! :)
Feb 11, 2007. 9:03 AMjoemonkey says:
that's pretty cool, but it looks like the pump action blowgun that i looked at.=|
May 16, 2009. 3:46 AMsharlston says:
what pump action blowgun?
May 27, 2007. 7:45 PMpyro13 says:
dude, i just load them into my mouth and machine gun them out
Feb 5, 2009. 9:23 AMavwos says:
WOW! so original.
Aug 5, 2008. 12:36 PMbowhunter08 says:
if you get a old broken carbon arrow you can shoot bb tourght it
Jan 31, 2008. 4:19 AMjakee117 says:
u can make an airsoft blowgun by just using an old airsoft barrel, i used to have a spring m16, broken so we used leftover parts i would say w/ that barrel about 180fps... not that high probably lower but it still stings... last resort weapon...hehe
Jan 18, 2008. 8:36 PMtwenglish1 says:
you could probably try one of the pencil grips to cover the breech hole
Oct 22, 2007. 3:01 PMJohawk says:
lol this works much better then I thought it would. I simply took the barrel from my old AEG and covered the hole on the top with a peice of highlighter cap, stuck a BB into the end, aimed at my knee, blew as hard as I could, and my knee nearly turned purple.
Jun 26, 2007. 6:51 PMtbj0820 says:
you can mack a mag out of a bic pen and put in hole
Mar 12, 2007. 2:14 PMcasvandegoor says:
ah ha now I understand!
Feb 17, 2007. 11:22 PMmanonfire285 says:
I made a frickin' AWESOME version where it can be semi- or automatic. It stills shoots airsoft BB's. Mine can carry up to 15 BB's in its magazine. Will post instructable soon to give you more detail!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bigpinecone
