If you want to start home brewing, or step up from that 20 quart pot you have been using, this is the Instructable for you.  A keggle is great vessel for heating your brew and can be obtained for a relatively low price.  The 15 gallon capacity of most kegs makes it possible to boil whole five gallon batches.
If your missing any of the tools that I use in the instructable, stop by Techshop and use our tools instead.
Step 1: Tools and Supplies
Your going to need a few things for this project.
  • Step-Drill bit - Should be able to drill up to a 3/4" hole.  You could use another drill bit, but a step-drill bit will make the process much easier.
  • Hammer and Chisel - You can use a flathead screw driver instead of a chisel if need be.
  • Small Flathead Screwdriver - Just need a small wedge to pry off the retaining ring.
  • Pliers/ Vice Grips -  Need to be big enough to grab the interior part of the weldless fitting.
  • Wrench -  must be proper size for the exterior of the weldless fitting.
  • Drill Bit - For creating a hole for plasma cutter to slide into. 1" worked for me.
  • Hand Held Drill
  • Drill Press - optional, could use the hand drill instead, but will be a little easier with a press.
  • Angle Grinder and Flap disc
  • Plasma Cutter
  • Mig Welder - If you don't have one, something like J-B Weld should work.
  • Keg - Craigslist is a good place to find these.
  • Weldless Ball Valve Assembly -  These are pretty easy to find at online brew stores.  Here is a similar one to mine.
  • Scrap Metal - For making the jig
  • Safety Gear - welding gloves, safety glasses, welding helmet.
As a note, I did not take pictures of the first 4 steps (up to cutting out the top) as I was actually doing them.  So the pictures seen are re-enactments,  you may notice the blue masking tape holding the lid in place.
streetrod5 says: Mar 27, 2013. 1:55 PM
Great job - I like how you made a jig to cut a nice circle with the plasma cutter. I've always messed up my freehand cuts, so that is a perfect solution. I believe the jig could be modified to accommodate an angle grinder (maybe using one of the grinder's threaded handle mounting holes).
I saw one video where they tied a rag over the valve and then released the pressure with a long screwdriver.
Prost!
NovelUserName says: May 3, 2012. 10:58 AM
Nice instructable, I think you covered the basics here pretty well.
I made a very similar with less sophisticated tools last year. I used a loop of string and a sharpie to mark a circle around the keg's valve. Then I used an angle grinder with a cutoff wheel and some patience to cut out the top. If you have a steady hand this actually works pretty well. I mention it because many of us don't have access to a plasma cutter, so we need to find an alternative solution.
Also for others who might want to try this: I wasn't able to remove the valve on mine despite some hours of fiddling, so I left it in when I cut the top out. As long as you make sure the pressure is drained before cutting, this works out OK.
One other thing I did which was very helpful is I made sure that the opening I cut matched the glass lid for my pasta pot (standard 10 inch lid I think). It's nice to be able to put a lid on the keggle while you are chilling/draining the wort.
Lastly I'd reccommend getting a ball valve assembly with a pickup tube. This will help you siphon all the wort out down to about 1/2cm left at the bottom of the keg. Otherwise you will 'lose' some liquid below the level of your valve.
Cheers
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
