Introduction: Bridal Jewelry on Making a Pearl Wedding Necklace With Ribbon
This is a ribbon and pearl necklace for wedding, you can make you own pearl wedding necklaces through this tutorial.
Step 1: Materials on How to Make a Wedding Necklace
4mm white pearl beads
6mm white pearl beads
8mm white pearl beads
6mm white crystal beads
Crimp beads
Tiger tail
Pink ribbon
Iron needle
White sewing thread
Wire cutting plier
Flat plier
Step 2: Make a Beads String
1st, cut down a 80 cm tiger tail, fold it in half and thread a crimp bead to it, the crimp bead is 0.5cm away from the end of the wire, flatter the bead by flat plier, thread a 6mm bead, a 4mm bead and a 6mm bead to the upper wire, slide a 8mm bead to lower wire, add a 6mm crystal bead to both ends of the wire; continue to add pearl beads with the opposite direction, then add a crystal bead on both ends, you can see the bottom-right corner picture;
Step 3:
2nd, continue until you use up twelve 8mm beads, use a crimp to fix the other end of the tiger tail, cut down extra wire and the beads string is done.
Step 4: Connect Ribbon to Beads String
1st, prepare two 15cm pink ribbon, connect ribbon to both ends by tying a knot, stitch the ribbon so that the ribbon fix the beads string tightly;
Step 5:
2nd, at last, tie an adjustable bow knot, the pearl wedding necklace is done.
Step 6: The Sparkling Ribbon and Pearl Necklace Is Like This:
Ok, the tutorial on how to make a wedding necklace is over, I think it might be a piece of cake you to make this ribbon and pearl necklace, I hope it can bring you other inspiration on DIY pearl wedding necklaces , look forward your reply.
