iImage Information
Want to see a light bulb in a glass of water light up in the microwave? To perform this trick you will need a glass of water an incandescent light bulb and a microwave oven. It's safer than some of the mildly amusing party tricks I know but occasionally strikes fear into the meek. If you don't want to risk it in your own microwave you can usually find all that you need to pull it off at an all night convenience store. They may charge you for the bulb and the cup of water but as long as you bet a non believer $10 that it will work, it should all be good.
Step 1Locate a glass or ceramic cup and fill it up most of the way with water
iImage Information
The cup or glass should be of a diameter that will support the bulb in an upright position above the water. Fill the glass with water enough that it just covers the part of the bulb that you would screw into the socket.
